62Ranchero200
Greetings Ford Six Fans:
In summary, I have a '62 Ranchero with a 250 and aluminum head. I'm currently running the 274/274/108 cam and I want more mid-range torque and mid-to-high RPM HP. I just swapped my C-4 for a T-5 so I think that will allow me to run a longer duration cam profile without serious idle quality issues, and I think a long duration cam would complement the T-5 and the upcoming 3.80 Traction Loc very nicely.
Classic Inlines offered a 280/280/108 hydraulic cam. This is still visible on the Vintage Inlines CI archive site, but not listed for sale by Vintage Inlines. I e-mailed Vintage Inlines in case the cam is available by special order, but if not, could it be ordered from Clay Smith?
Since I now have the T-5 and a friend is building the 3.80 Traction Loc, I was hoping to warm up the 250 a bit more by milling the head for higher compression, and installing a higher lift, longer duration cam. I don't want to go solid lifter at this time because I don't want to have to keep pulling the valve cover to adjust lifters.
Thanks,
Bob the Builder
Thanks,
Bob the Builder
