Throttle Return Spring
6ponies
I have a Holley 500cfm 0-4612) on a CI aluminum head and intake. I realized I do not have a good place to install a return spring.
This is one of my options right now and I've seen some of you use it:
I wanted to see what some other ideas might be out there.
Hi, the kind of return spring set ups you are looking at work great. Good luck
Thanks for the input. The one from Lokar wouldn't work because I'm not using a cable for my throttle. I ended up getting the one from Mr. Gasket. It seems to work out pretty well.
Thanks for getting back with us. It's always good to know what worked. When you're searching google and forum threads about some problem you need help with and they dead end, it sucks. I know it's a short thread, but still thanks.
Boy, those R great links guys.
The 1st (Holley) has 8 pages (15 listings per) from 4 manufacturers.
The 2nd leads to Lockar's whole catalogue…
Thnx!
