Howdy,
I was reviewing my Ford shop manual in perpetration for the cylinder head installation on our 170 and came across a question. In the manual it says to torque the rocker arm pedestals two turns in sequence up to spec. I found the spec at 35 ft/lbs but can't find anything about the sequence. A quick search here on the forum says to start in the middle and work towards the ends, is that correct?
Thanks,
Kevin
Thanks,
Kevin
