Yes, break-in is different (short run - 30 min @ 2,ooo rpm or less?) requires a hi ZDDP oil. It gets drained right then - look in pan for metal filings beyond the norm, cut open filter if showing 'chunks' & examine that 'byproduct' (frm inside filter). Some use "break in oil", I have less expensive (Luckas I believe) additive mixed to each qt as it goes in that 1st running/starting/tuning. If going that more expensive route - Brad Pen is used by many here.
After that (usually 1st 500 mi of test driving) again change oil. This 2nd fill is not w/'break-in" oil, but continue close exam of what's drained. Some use 10w30 (some still want the 'zink' additive often for the duration, not I). 10w30 winter/10w40 summer, 3 - 5,000 mi changes thereafter…
Do U have 'hardened seats"? What rings?
Many opinions, but that's one.
Let us know how U go...
