My bad the 1290 pump comes out higher on the inlet hose compared to the cast iron pump.wsa111":1e8k9azh said:Take a good look, the inlet fitting is not angled down like the iron pump.
That means will your lower radiator stretch that far to connect to the pump inlet??
