Hello All, Thanks for following my story and contributing ideas. This site is awesome! Well, I noticed that while I had great idle and smooth operation, I felt that the motor was still lagging a little pep, even for a 144. I advanced the timing to 12 btdc, and operation improved greatly with no ill effects. I'm guessing most of you have discovered that your motors run much better at a higher advance than "spec."
Question for today: Are there some kind of seals inside the 2.77 transmission where the shifting shafts come out the side? I'm getting some trans oil coming out around those shafts.
