1974 250 length
HI
New to the forum . can someone tell me the length of a 1974 250 from the back of the engine to the water pump flange, or the overall length minus the fan I need the measurement for a project i an working on. I am working on a 1987 range rover and would love to put a inline 6 in it.
thanks
30.5 " from the back flange to the front of the balancer if its one pulley long. Same as 200 with one belt pulley.
However, 250's ran 2 or 3 belts, so were longer always by more than 1/2". Same with 5, 6 and 9 rib serpentine belts as used by some others here(Broncitis, balldrick, Mike1157, and the planned kit by the late Mike W (AzCoupe)from Classic Inlines.
Broncitis
balldrick
/viewtopic.php?f=22&t=56560
Mike1157
http://vb.foureyedpride.com/showthread. ... la-Monster)/page8
The difference is the height of the water pump. Mike1157 removed it, and then the only differnce was the length of the lower pulley. His was serpentine.
http://vb.foureyedpride.com/showthread. ... la-Monster)/page6
"http://vb.foureyedpride.com/showthread.php?155706-The-path-less-traveled-1978-Turbo-I6-Futura-(The-Gila-Monster)/page6"
See http://vb.foureyedpride.com/showthread. ... swap-help-!
included is this
The water pump is 4.5", or half an inch longer than the pr 1978 water pump for the 200
(they were 4"on 144/170/200's before 1978)
See http://vb.foureyedpride.com/showthread. ... conversion too
Thanks for the info. I checked the engine compartment today and I have 33.5" from firewall to radiator, so should fit with only minor hacking and welding.
