I ran the hot wire that originally went to the old coil to the hot on the hei. That's all I did, still runs on the key the old way. I still need to get cut to fit wires and make plug wire brackets. As for other electrical I adapted a chevy 1 wire alternator and I'm running the wire straight to the battery so no need for any of the old rectifier and made the wire harness much smaller.chad":biucz700 said:good to hear about your progress, thanks 4 comin back.
I see you have an HEI distrub on there...what R the other components in ur ignition system?
