I'm contemplating building either a 170 or 200.
I got a line on a pair of engines in my area. The owner got a 170, 200 and 250 from a neighbor years ago who was moving and was going to scrap the engines. The owner has plans for the 250 but is selling off the 170, 200 and what I think is a 2 speed ford-o-matic that had been mated to the 170. The 170 came out of a falcon. Doesn't know where the 200 came from, or the history on either engine as far as if they've ever been rebuilt or what condition/miles when pulled. The 170 has been repainted. The valve cover was painted blue over the original red. It happened long ago enough that the red is showing through in spots.
The codes on the 170 are C1DE-6015-A for the block and C1DE-6090-A for the head. For the 200 I only have that the sticker on the valve cover starts with D5DE. The owner is going to take a better look at the 200 today or tomorrow and hopefully I'll get the the rest of the block and head codes then.
I'm looking to build an engine to someday put in a round body falcon. I'm fairly sure I can get more power, etc,... out of the 200. But my inclination is to rebuild the 200 head and swap it onto the 170.
Couple questions:
1. My research on the 200 is a little foggy for the 75 head. Am I correct that this year has the 1.649 intake valves? But can be machined to take the 1.75 valves from the 77 and up head?
2. Also on the 200, I think I'm looking for a "flat top log" for easier machining to accommodate a 2V carb. Will the rest of the head code be enough to tell me if this engine is flat top vs hexagonal or will I have to physically pull the carb to verify.
3. Is building 170 feasible with this 200 head? Is there enough meat between the 200 head and 170 deck to machine off enough to achieve a combustion chamber volume small enough to achieve a good compression ratio?
Thanks for sharing your knowledge in advance.
Couple questions:
