2018 Contributors:
New cylinder head
cmm24601
New cylinder head
Post #1 by cmm24601 » Wed Sep 13, 2017 10:37 pm
Just purchased a 1970 cylinder head to replace the head on my 1969 250.
I'll take it to a machine shop for a valve job, but is there a good tutorial on installing it?
1969 Mustang Grande
250 inline 6
Automatic Transmission
Autolite 1101 Carb
Econoline
Re: New cylinder head
Post #2 by Econoline » Thu Sep 14, 2017 2:09 am
If it still has 62cc chambers you're going to want to have it milled .025" or so to keep the compression @ 9:1 with a new thicker composite gasket. It's good to get a couple of bolts from the hardware store or old head bolts and cut the heads off of them to use as guides when putting the head back on the new gasket. Other than that and having the deck good and clean, there's just torque sequence from the center out in a circle with 3 progressive intervals to the final torque.
ci/SmallSixSpecs.html#TorqueSpecs
It ain't gonna fix itself
CZLN6
Post #3 by CZLN6 » Thu Sep 14, 2017 9:18 am
Howdy:
FYI- The '69 and '70 heads are virtually the same casting. what's the point of this change?
cmm24601
Post #4 by cmm24601 » Thu Sep 14, 2017 10:25 am
My current head is pretty beat up. Crack on the intake manifold, threads broken at the ends where the exhaust manifold mounts. And i have a persistent vacuum leak. I found this 70 head for a decent price and it's in better shape.
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
drag-200stang
Post #5 by drag-200stang » Thu Sep 14, 2017 11:12 am
When using guide pins,use the passenger front and rear bolt holes. The holes in the head and gasket are made smaller at those locations for that alignment purpose.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
drag-200stang
Post #6 by drag-200stang » Thu Sep 14, 2017 11:24 am
Do not forget to use sealer on the front passenger bolt , it is open to the water jacket...If using studs make sure you clear the water pump impeller at that location.
66 Mustang Coupe
ags290
Post #7 by ags290 » Thu Sep 14, 2017 11:54 am
X2 on the thread sealer for the front bolt. X2 on getting the head milled to compensate for the thicker head gasket. Make sure that when you add coolant back to the system that you get all of the air out. I had to end up getting help from the forum to finally get the last of the air to purge. The trick was to to get the nose of the car elevated when refilling the system.
Good Luck
Kevin
Kevin
Early 1965 Mustang with a 170
chad
Post #8 by chad » Thu Sep 14, 2017 2:00 pm
"...re-establish the oil transfer slot..." there's an oil passage to examine after milling too (depending on amount removed)...
Y not get all the install tips & a lot more from the "Handbook" (see Matt at vintage inlines dot com - aprox $25) and while waiting for delivery see our "Tech Archive" (for free - above by clicking on it)? Can't go wrong w/these sources. If U do...
we're all ways here with a guiding hand!
wsa111
FSP Moderator
Post #9 by wsa111 » Thu Sep 14, 2017 3:08 pm
Man, you guys got it down pat. Best of luck on the swap.
CZLN6
Post #10 by CZLN6 » Thu Sep 14, 2017 4:23 pm
Howdy Back cmm and all:
Ahh, I get it now. FYI the stock head gasket is .025" thick. The new composite gasket that you will get in a valve job gasket set is approximately .050". To maintain stock compression ratio, you will need to have the head milled .025".If you would like some very inexpensive torque you might want to consider milling the head even more; say .050" for an increase of a half a point more CR. I say inexpensive because the milling will cost just a bit more, you will need to re-establish the oil transfer slot and you may need washers on the head bolts to keep them from bottoming out.
Questions? Keep us posted.
chad
Post #11 by chad » Thu Sep 14, 2017 6:29 pm
chad wrote:there's an oil passage to examine after milling too...
"...re-establish the oil transfer slot…"
like he said!
Ck out da Handbook
8^ )
Econoline
Post #12 by Econoline » Thu Sep 14, 2017 10:08 pm
I'm glad you guys remembered the goop on the front bolt in the water jacket, very important! I knew I was forgetting something
Op, while you have the head off you should measure the deck clearance on the #1 and #6 cylinders and cc the new head and then you can dial in the compression to 9:1-9:3. It's worth the effort.
cmm24601
Post #13 by cmm24601 » Mon Dec 11, 2017 7:51 pm
Fi-----nally got my cylinder head back from the machine shop. looks good though.
I've ordered the performance handbook from vintageinlines.com
Does this engine have hydraulic lifters? How do I make sure the vales are in the right place?
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
bmbm40
Post #14 by bmbm40 » Mon Dec 11, 2017 8:19 pm
These guys are good.
Did you do a 3 angle valve job or back cutting? Port and polish?
What are you using for an ignition system?
Econoline
Post #15 by Econoline » Mon Dec 11, 2017 9:38 pm
Your engine has hydraulic lifters. You'll be fine with the old valve train b/c you're just doing the head, and if it was cut .025 you're just cmpensating for the old steel .025" head gasket for the new .050" composite felpro gasket. Did you take any measurements?
cmm24601
Post #16 by cmm24601 » Mon Dec 11, 2017 9:58 pm
what do you mean by deck clearance Seth?
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
JackFish
Post #17 by JackFish » Mon Dec 11, 2017 11:49 pm
bmbm40 wrote:These guys are good.
Yes on valve job but negatory on the polish.
I would have the valve pockets ported out though.
And DS2 for me on the sparks.
oops responded to the wrong post :oops:
I see the head is done.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
cmm24601
Post #18 by cmm24601 » Wed Jan 03, 2018 9:14 am
The new head is on! Looks great. Soooo clean. Sooooo not cracked anywhere. :D :D
Just to confirm... No adjustments necessary? This thing just bolts on? I'm going to coat the rockers and rods in some oil, put on some oil, fill the fluids and fire it up?
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
B RON CO
Post #19 by B RON CO » Wed Jan 03, 2018 1:36 pm
Hi, yes, it sounds like you are getting there. You should have thread sealant on the front right head bolt because it goes into the water jacket. I'm guessing you never took the lifters out. We used to put a dab of white lube on the valve stems and push rods because it won't go away if the engine sits before starting. I don't put in antifreeze, just water, so if water starts leaking I don't worry about that, until I know it's good. Just don't let it freeze this time of year. If you didn't remove the distributor the timing should be good. It will take some time for gas to get up to the carb, and after that you'll be on your way. Good luck
1966 Ford Mustang - 289 V8
cmm24601
Post #20 by cmm24601 » Wed Jan 03, 2018 4:55 pm
Sweetness. Good tip on the water.
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
chad
mounting New cylinder head
Post #21 by chad » Wed Jan 03, 2018 8:45 pm
1) "...getting the head milled to compensate for the thicker head gasket."
2) "Did you take any measurements?"
3) "...what do you mean by deck clearance Seth?..."
The above three parameters R important on reassembling a motor.
1) The last head was in tough shape but I'm not sure if it still had the steel shim gasket. You R not just truing the surface (back to level) so head & block meet tight, but compensating for compression volume as the replacement gasket is way thicker than the ol steel shim style.
2) "Measurements" as Seth wrote might involve the combustion chamber in the newly machined head (term of "CCing the head") due to this mill pass reducing the volume.
3) Deck clearance refers to the amount of surface hight left above the piston at the block.
Last but far from least:
Here's hopin U followed up with the reading ("Handbook" &/or Tech Archive above). U may not need echo1955's (or is it 95? - Ron Perlmutter) vid as he goes thru Total Assembly but it might B nice to spend some time on YouTube to get up to speed on the process you'll B undertaking for the 1st X...
woodbutcher
Post #22 by woodbutcher » Thu Jan 04, 2018 8:25 pm
:hmmm: A little hint on starting a fresh engine so that you don`t have to grind on the starter and wear down the battery.Learned this little trick about 45 or so years ago.Take one of those funnels that you fill a Coleman stove or lantern with and put a short(about 4")piece of fuel line on it and use it to fill the float bowl on your carb.Saves a few discouraging words :rolflmao: .
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
cmm24601
Post #23 by cmm24601 » Fri Jan 05, 2018 9:49 am
The conclusion of the matter:
Filled it with fluids, no leaks except for forgetting to tighten the thermostat housing. :bang:
Fired right up. Test drove it this morning. 12 miles. Smoooooooooth idle. So smooth I started noticing all the other rattles and buzzes in the cab. ;) I'll retune and check everything this weekend but I think it's good.
Thanks for the help!
Now to sell my old head... Do you guys recommend selling the whole thing (even in rough condition) or parting out?
1969 Mustang Grande
250 inline 6
Autolite 1101 Carb
chad
what to do w/my '69 rare "M" head
Post #24 by chad » Fri Jan 05, 2018 11:17 am
Conrats Dooood! That was fast!
I would hold onto that head. In the yr'n 1/2 you've been round here U may have seen "direct mount", "2v" & "4v carbs" in the threads' chat (of this forum right here). The head U have is 1 of the best for these mods. If it is in good shape (magnifluxed 4 cracks, no 'lost ears' or castings, pretty flat @ gasket area, etc) U could 'work it' and have a performance head on ur rig in 1/2 a day.
On the otherhand:
If U don't want better MPGs & pep, have no room for storage, need $ to recoup what U put into the 1970 head I wouldn't blame U for puttin up an add in our "4 sale" forum...
Win/Win either way!
:thumbup:
bmbm40
Post #25 by bmbm40 » Fri Jan 05, 2018 8:42 pm
That's the way to do it... fires right up, drives good, idles smooth. No stress just fun.
Users browsing this forum: No registered users and 15 guests
