need to change the fuel pump before the snow fly's..running the 3 webers with a fuel regulator..i see that there are different gals per hour 18 to 25..does this mater.
Its probably not going to mater all that much since they are so close but, I would probally go with the higher volume pump since you are using the 3 Webers and a regulator too. Good luck
thinkin ur a candidate 4 the Carter Street/Strip (I think it's called) or is it Carter Strombourg?
Any way, did U C the tech article on here abt it - all U need to do is switch out the cam arm that pumps it...
