ssg66stang
So, in a week or two I will be at the point that I want to replace the factory distributor on my I6. I was initially going to purchase a DUI distributor (from VI) after reading several articles that stated it gave a better "bang for your buck" (easier to install compared to the DSII, better power gains, easier to maintain, and a setup that looks a bit cleaner) but since then I have heard/read that DUI's are sometimes nightmares. So now, I'm confused... Has anyone used both and now favors one? Any experience and advice is more than welcomed.
In addition to that, can someone explain the difference between the DSII and the DSII "performance" distributors? Is it worth the $185 price increase over the "standard" version of the DSII?
Do I need to run vacuum advance and centrifugal?
Does anyone know if the DUI distributors from VI have vacuum advance?
Thank you!
Thank you!
