Push rod Length Checking Tool.
Marco, what are you running for rocker arms???
99% sure the 1.6 adjustable from RAU. Matt got back to me and the YT 1.65 will not be available for my build. They will be coming in from Aussie at an unknown time.
Are you running the stock non oiling lifters??
Remember the Yella-Terra rocker arms require the V-8 oiling through lifters & oil through pushrods.
Plus with the Yella-Terra rocker arms you need to block the oil supply to the head otherwise you will have an oil leak at the ls headgasket area.
You are at a point where you need what you want to do??
RAU does make a 1.65 rocker that is shaft mounted, but it's not cheap. If you call and talk to Gary, he should know the setup.
Marco, another option is if you plan to go the Yella-Terra route, install the V-8 lifters which are .150" higher. Than get a set of non oiling pushrods .150" shorter & run the shaft oiling rockers, then when you go the 1.65 full roller deal the V-8 lifiters will already be broken in on your present camshaft.
Using non oiling pushrods on oil through lifters is not a problem.
If you already have the non oiling lifters in your engine & are broken in already, go back to plan A, 1.6 rockers.
