Priming new engine
theman1990
Active member
Oil priming: how much should I be seeing? I know on small block fords it gushes out... I'm seeing a slow cascade at the back of the engine but that's it.... Where and how much should it be?
put head on 2 complete oil path way (if not doing so as of yet).
U will C the whole 'circuit' & have more info.
Any oil cascade out of the back of the engine is never good :) That's all on him, how do you miss 2 pedestal bolts when you do valve jobs for a living? That's why they're the experts, you pay them to know sh*t
Fords generally run higher oil pressures than say, like Chevys on the other side
