2018 Contributors:
Noisy lifter after head gasket swap
Cday07
Post #1 by Cday07 » Tue Jul 17, 2018 10:34 pm
Hello everyone,
Recently driving the mustang home from an evening out with the misses, the car developed a sudden exhaust leak. I traced it to the head gasket, number 3 cylinder, and proceeded to replace it with a Fel-Pro gasket. No longer have an exhaust leak, but upon driving the car for about a mile, it became apparent there’s a noisy lifter on cylinder 5.
Is this a symptom that will go away with time or is something worse lurking under the hood now? It was fine before the swap, and the head was off the car for about 48 hours before reinstallation. Is it possible oil simply drained out of the lifter and needs to fill back up (I didn’t place any parts in oil while working on it)?
Thanks, Chris
65 Mustang 200 Viper Red, HEI ignition
Econoline
Re: Noisy lifter after head gasket swap
Post #2 by Econoline » Tue Jul 17, 2018 11:58 pm
You mean exhaust gasket, not "head gasket". I would pull the valve cover and get a visual on the offending racker/lifter/pushrod. Pull the plugs so you can more easily turn the engine over with a ratchet/breaker bar ect and see what's going on.
It ain't gonna fix itself
1964 Econoline 170 3.03 on the tree swapped to a 250 with an aod, custom front boosted disc brakes and 3.70 9" rear axle
1993 F-150 xl 4x4 4.9 5-speed, Mazda manual stock
1992 Jeep Cherokee 2-door 4.0, 5-speed manual
1989 Toyota Cressida 3.0, auto
B RON CO
Post #3 by B RON CO » Wed Jul 18, 2018 1:40 pm
Hi, if you did in fact pull the head, I hope you drained the oil. It is very likely coolant dripped into the crank case and may cause the problem you have.
I have done head gaskets and valve jobs and left the lifters alone in the block.
Most guys keep the push rods in the order they came out. If they got mixed up, that could be a reason for the noise.
If the rocker arm and push rods look Okay I would change the oil, I like Castrol GTX 10W 40, and add a bottle of Marvel Mystery oil.
Good luck
1966 Ford Mustang - 289 V8
Users browsing this forum: No registered users and 33 guests
