PVC
mluck
Years ago I got a edelbrock valve cover..it has a hole on the side,back of the cover..I found a Honda pvc valve with the grommet ..my question is do I run a hose from the pvc to the vacuum outlet on the head..I have seen some falcons that run the hose down the engine close to the ground..now I also have the offy with 3 Weber’s..
Yes run the PCV hose to the log intakes port (below the carb). Good luck (y) :nod:
U might 'close' the system (continuous or closed system PVC) w/a return frm frnt of VC to air cleaner housing (not sure how U changed that prt 4 a Triple).
I would not run a honda. (Design & displacement R different).
