2018 Contributors:
Speedo gear
StarDiero75
Speedo gear
Post #1 by StarDiero75 » Thu Aug 09, 2018 3:28 pm
Howdy guys!
So i noticed my speedo is off, even though when i changed the transmission i got the same exact one, ie 1965 3.03 for a 1965 3.03 same casting nunber and revision and all. Im guessing someone swapped the gear out on the tailshaft for some reason.
The speedo says 40, im doing 36
Speedo says 75 im doing 67
Using these ive calculated what im doing when it says 60, and im actually doing 54.
I believe currently i have a 19 tooth gear, so since im roughly 5 off at 60, do i go up by 1 tooth to 20?
Thanks,
Ryan
--1965 Ranchero w/1966 200, dual friction diaphram 9" Modern Driveline clutch and billet flywheel all balanced, 1985 SVO WC T5 with front shift, 1966 2.8 Ford 8", Weber 32/26 with VI adapter, CRT Performance HEI.
wsa111
FSP Moderator
Re: Speedo gear
Post #2 by wsa111 » Fri Aug 10, 2018 1:21 pm
Ryan, yes give the 20 tooth a try.
chad
Re: Speedo gear
Post #3 by chad » Fri Aug 10, 2018 5:41 pm
"...3.03..." rear gear
and what sz tire/wheel?
mustang6
Re: Speedo gear
Post #4 by mustang6 » Sat Aug 11, 2018 2:37 am
We can do a little math with your observations:
40/36 = 111.11%
75/67 = 111.94%
19 X 111.11% = 21.11
19 x 111.94% = 21.27
So I would say you actually need a 21 tooth gear.
Scott
StarDiero75
Re: Speedo gear
Post #5 by StarDiero75 » Sat Aug 11, 2018 5:05 am
mustang6 wrote:We can do a little math with your observations:
40/36 = 111.11%
75/67 = 111.94%
So just kidding, i have a 16 tooth in the car. I dont know where i pulled 19 from but i just checked and jt is 16. I will use that math though, thanks!
StarDiero75
Re: Speedo gear
Post #6 by StarDiero75 » Sat Aug 11, 2018 5:06 am
So 16×1.111 is 17.777. So an 18 tooth it is.
Thanks a lot!
drag-200stang
Re: Speedo gear
Post #7 by drag-200stang » Sat Aug 11, 2018 10:08 am
I would check that the odometer matches your speedo findings...They are tied together...It may be just the speedo that is off...It has been a long time, but I thought that there is an adjustment for just the speedo.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
StarDiero75
Re: Speedo gear
Post #8 by StarDiero75 » Sun Aug 12, 2018 12:34 am
drag-200stang wrote:I would check that the odometer matches your speedo findings...They are tied together...It may be just the speedo that is off...It has been a long time, but I thought that there is an adjustment for just the speedo.
No the odometer is matching the speedo. My drive to canada was only about 180 miles, and it recorded about 200 miles.
PS, i drove to Canada in the Ranchero doing about 72 (actual mph, it said 80 mph) for 3 hours. Im so proud, and even happier that i proved my mother wrong that it would make it there and back with no issues.
Users browsing this forum: No registered users and 24 guests
