2018 Contributors:
67 mustang - 300 head vs 200 head
thestang
Post #1 by thestang » Mon Sep 17, 2018 2:41 pm
Hey guys i am trying to upgrade my cars performance and will soon added forced induction.
I really want to put a 300ci head in but dont know what to do or if i would need make mods. My car has a new brake system and new suspension. Please any advice
What do you think i should do buy a new 200ci head:
https://sdparts.com/i-24080251-atk-2f29 ... SYEALw_wcB
Or a 300ci:
https://www.jegs.com/i/ATK-Engines/059/ ... hlEALw_wcB
Re: 67 mustang - 300 head vs 200 head
Post #2 by bubba22349 » Mon Sep 17, 2018 2:56 pm
A 300 / 4.9 big block six cyLinder head won't fit on a 200 / 3.3 engine or any of the other small block six engines. Good luck on your project build :thumbup: :nod:
thestang
Post #3 by thestang » Mon Sep 17, 2018 3:14 pm
bubba22349 wrote:A 300 / 4.9 big block six cyLinder head won't fit on a 200 / 3.3 engine or any of the other small block six engines. Good luck on your project build :thumbup: :nod:
What are my options :(? Is
There any head that would fit as an upgrade
chad
Post #4 by chad » Mon Sep 17, 2018 4:00 pm
"The Ford...6 Cyl Performance Handbook" frm Matt at vintage inlines dot com (20 $ ?) sounds like a resource U could really use. While waiting 4 delivery ck the above tech archive (@ big blue bx w/crossed screwdriver/wrench). All ur Qs should B answ there.
After gettin up to speed U will have more specific info on the end product U seek.
At that point we can really aid U in the particulars.
ID all ur components 1st (again the Handbook helps) so U know where U R @ now. If U have been drivin the vehicle awhile U can get an idea of where U wanna go frm here (80% of ur use conditions).
Kinda like a house. When U 1st buy/move in it's better to "live it" awhile insteada just tearin out the kitchen'n throwin in a new 1. Over the period U research what's out there, C how usable the kitchen (& whole house) is, take time to redesign a useful to you one, save money, etc. Hope that's not too patronizing. I just see alot of vehicles ruined around here when a knowledgable, thoughtful approach is not used. Money'n time waisted & worse (as I have alot of care/enjoyment of these rigs) the vehicles themselves.
"...will soon added forced induction."
We have a forum on this site 4 that.
bmbm40
Post #5 by bmbm40 » Mon Sep 17, 2018 8:30 pm
Check out the vintage inlines highest performance available aluminum head. It is totally awesome.
StarDiero75
Post #6 by StarDiero75 » Tue Sep 18, 2018 1:12 am
But if you cant afford the $2100 aluminum head, you can modify a 250 l6 head for a 3x1 setup.
--1965 Ranchero w/1966 200 and 3.03 column shift, 8" rear 2.8 (Yes I know the gearing sucks), weber 32/36, CRT Performance HEI.
CZLN6
Post #7 by CZLN6 » Tue Sep 18, 2018 10:16 am
Howdy The Stang and all:
If you are going to forced induction why are you considering changing heads. Forced induction will take care of flow issues. What is your engines current condition? Year? Miles? Transmission?
FYI a 1980 200/250 cylinder head will offer you all the best that FoMoCo has to offer. The 200 head you posted seems expensive to me.
Where are you located?
thestang
Post #8 by thestang » Tue Sep 18, 2018 10:37 am
CZLN6 wrote:Howdy The Stang and all:
All original 67 mustang. The headgasket is like melted but doesnt leak yet so i wasthinking about replacing it.
I live in Nj
thestang
Post #9 by thestang » Tue Sep 18, 2018 10:38 am
CZLN6
Post #10 by CZLN6 » Tue Sep 18, 2018 11:18 am
Howdy Back:
Nope. The 240 and 300 six cylinder engines are a different engine. The 240 was used in full size Ford cars and the 300 was used in pickups and vans. These engines are physically larger and heavier the the small six engines which includes 144, 170, 200 and 250 engines. About the only item that is interchangeable is the one barrel carburetors.
thestang
Post #11 by thestang » Tue Sep 18, 2018 11:37 am
CZLN6 wrote:Howdy Back:
Okay so what donor car could i look for that would have a 250ci cylinder head?
Post #12 by bubba22349 » Tue Sep 18, 2018 11:58 am
Looks like it's a typo "240 head" in your above post by the pictures it shows a 1969 to 74 "250" head yes its probably a little better head than you have now. Though if your going to buy a head and change it out then why get the one that "CZLN6" recommended to you? In a stock replacement cyclinder head for your 200 it is the best stock Ford head you will be able to find. https://www.jegs.com/i/ATK-Engines/059/2F66/10002/-1
Also Remember in your head search theat the later model 200 and 250 heads are both identical. Good luck :thumbup: :nod:
chad
unKnown increased performance
Post #13 by chad » Tue Sep 18, 2018 12:20 pm
Gotta start @ the beginning:
After gettin up to speed U will have more specific info on the end product U seek. UR Qs will B more specific/informed. We can B more of a resource 2 U. There R no short cuts to quality results.
Ford goes by 'families' not small block / big block like chebby.
The i6 family (1960 - '96) is bifurcated into 144, 170, 200, 250 as the small 6; and the big six 240 and 300.
thestang
Post #14 by thestang » Tue Sep 18, 2018 12:25 pm
bubba22349 wrote:Looks like it's a typo "240 head" in your above post by the pictures it shows a 1969 to 74 "250" head yes its probably a little better head than you have now. Though if your going to buy a head and change it out then why get the one that "CZLN6" recommended to you? In a stock replacement cyclinder head for your 200 it is the best stock Ford head you will be able to find. https://www.jegs.com/i/ATK-Engines/059/2F66/10002/-1
So you like the
Vs the 250ci?
thestang
Post #15 by thestang » Tue Sep 18, 2018 12:35 pm
Also is the 250ci head a bolt on drop in? And what would i need to do to make it work?
rocklord
Post #16 by rocklord » Tue Sep 18, 2018 1:49 pm
The 80-84 200 head that bubba linked to at Jeggs is the best head to have, even over the 250 head. The 200 head has the largest intake log volume, largest stock valves, and hardened valve seats. It has the largest chamber volume, so if you are planning forced induction, so much the better.
I also recommend the Performance Handbook.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
thestang
Post #17 by thestang » Tue Sep 18, 2018 2:01 pm
rocklord wrote:The 80-84 200 head that bubba linked to at Jeggs is the best head to have, even over the 250 head. The 200 head has the largest intake log volume, largest stock valves, and hardened valve seats. It has the largest chamber volume, so if you are planning forced induction, so much the better.
Would that be a direct bolt on? Or drop in with no mods?
rocklord
Post #18 by rocklord » Tue Sep 18, 2018 2:32 pm
Yes and No.
Yes, the 80-84 200 head will bolt directly on your 67 engine, the 250 head will also.
The No side of the equation is the size of combustion chamber of both the 200 and 250 heads.
The original head on your 67 had a combustion chamber size around 53cc. Both the 250 head and later 200 heads had 62cc combustion chambers. Ford was able to keep the compression ratios (CR) high by varying the recess in the piston.
The chamber volume of any head you purchase will depend on how much has been milled off the mating surface. When you purchase another head, you will have to CC the combustion chamber to determine if it needs remilled, or if the pistons in your engine need smaller recesses.
Dan
Currently Own
thestang
Post #19 by thestang » Tue Sep 18, 2018 2:44 pm
rocklord wrote:Yes and No.
What if i wanted low compression ratios damn. I need start studying. So id have to take the whole engine out?
chad
unKnown Performance upgrade Qs
Post #20 by chad » Tue Sep 18, 2018 4:14 pm
"...start studying..."
then ask, we can help but a tutoring is tough.
Keep at it.
the Handbook, tech archive.
viewforum.php?f=94
viewforum.php?f=22
viewforum.php?f=48
(I'm not bein 'mean') just da opposite!
thestang
Re: unKnown increased performance
Post #21 by thestang » Tue Sep 18, 2018 4:49 pm
chad wrote:Post #4 by chad » Mon Sep 17, 2018 4:00 pm
Dawg the book is out of stock and i wont pay double the price to
Get it.
Curious what would happen if i just installed the head wothout milling it?
thestang
Post #22 by thestang » Tue Sep 18, 2018 5:06 pm
Rick i need your help bro. What would happen if i dont mill it?
Can you text me that way i could just text you my few questions that way i can order the head today?
929 255 0197
rocklord
Post #23 by rocklord » Tue Sep 18, 2018 5:40 pm
Get it.
You know, you could contact CZLN6, he's one of the authors of the Handbook. He might have one or two lying around to sell.
He's also posted several times to your thread. You might want to listen to him.
Dan
Currently Own
Post #24 by bubba22349 » Tue Sep 18, 2018 6:19 pm
929 255 0197
If you don't mill the head compression ratio will be a little less. Assuming that you 67 Mustang has the stock head with 51 to 53 CC chambers and pistions still it's compression Raito now would be 8.7 to 1 the late heads have 62 CC this is about 10 to 11 CC bigger combustion chambers add that too the new style head gaskets of .050 + compared to the stock steel shim head gaskets of .022 a rough guess is your compression will be in the 8.2 range fairly good for a Turbo or supercharger application. By the way I sent you a PM a long time ago on your questions. Good luck for n your build :thumbup: :nod:
chad
Post #25 by chad » Wed Sep 19, 2018 12:19 pm
thestang wrote:Dawg the book is out of stock and i wont pay double the price to
Get it.
Then there will B alot of 'teachin' done here. The book is worth 4X the price in my opinion.
They R being mailed frm supplier to retailer right now, sez Matt.
Y not speak to him (Matt) directly (post on VI site at "contact Us" rather than visit'n split)?
He's not some anonymous cypher caculatin away in cyber space, but a real human/member here like U'n I.
chad
'67 200 - 300 head vs 200 head
Post #26 by chad » Sun Sep 23, 2018 12:54 pm
"... the book is out of stock..."
looks "In" to me now...
Users browsing this forum: No registered users and 28 guests
