<<< New Site Update >>>
Cooling system needs
falcon_master
Post #1 by falcon_master » Wed Sep 19, 2018 10:59 am
Hi everyone, thanks for all your responses on the alternator questions I appreciate it. I called a few places and they said that a higher amp alternator is fine because even though it’s rated for 105 amps it won’t put out that much unless the load requires it. And so far 105 is the cheapest because it’s a bulk sale. But I did some math and found the basic amp usage of my car, the headlights are about 6 amps low beam, 8-9 amps hi beam, about another 4amps for taillights, so I have about 8 amps to play with after ignition system and instrument panel. But that’s off topic lol. My question today is my cooling system. Does anyone have experience on how well these things handle 90-110 degree weather In stop an go. It doesn’t have ac or power steering to out a load on it at idle. I’m thinking about putting a nice cheap 10 inch pusher fan or puller fan to make sure I have nice airflow all the time to help prevent overheating as on the freeway down there’s only one way to Phoenix and it gets backed up a lot. I don’t wanna overheat if I can help it. And I know the fan would be pushing my electric system but I wouldn’t use it unless I needed it, but if most people are ok in high temps I won’t worry about it. I imagine this 144 isn’t putting out to much heat lol.
Junior year high school AFJROTC cadet and car enthusiast. Likes all things ford and engines of any company. 64 falcon 2dr sedan,144CI and 3spd column shift. estimated 124,000 miles. Resurrected after sitting outside for 18 years, In process fixing for use as daily driver YouTube channel for repairs coming soon. “Old cars may break but are never broken”-RCR
frozenrabbit
Re: Cooling system needs
Post #2 by frozenrabbit » Wed Sep 19, 2018 11:20 am
You'd do better with a good fan shroud.
There's no room for an electric pull fan, and to fit a pusher fan you have to hack up the hood latch support brace.
Lazy JW
FSP Moderator
Post #3 by Lazy JW » Wed Sep 19, 2018 11:28 am
frozenrabbit wrote:You'd do better with a good fan shroud.
Yup. :nod:
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
chad
Post #4 by chad » Wed Sep 19, 2018 11:33 am
Some fairly competent engineers designed ur system to do that sorta driving.
However it's up to us to keep the system at it's optimal.
Make sure U have that shroud;
the fan blades spin 1/2 in & 1/2 out of it;
U done a good flush (that thing's been sittin so long make sure on this 1, inc. heater core);
have a new thermostat;
50/50% H2O'n antifrez/boil;
air purge @ fill (I use 1a the "tight fit funnels");
good belts'n hoses;
good cap & 'overflow' w/deep tube.
falcon_master
Post #5 by falcon_master » Wed Sep 19, 2018 11:57 am
Ok thanks everyone, one thing I stupidly forgot to say is if I went with the puller fan option I would get rid of the mechanical fan but I think I’ll stick with what I got first lol
chad
what's there optimal first, then mods
Post #6 by chad » Wed Sep 19, 2018 12:06 pm
ele fan along w/remote H2O pump, ele fuel pump'n efi/turbo R all dwn the rd 4 U I'm sure...
8^0
62Cometman
Post #7 by 62Cometman » Wed Sep 19, 2018 2:29 pm
I would measure how much clearance you have between the radiator and the latch support because i have about 2.75 inches and i put a 14 inch electric pusher fan on my car when I switched to a larger radiator so that is possible. if thats the route you want to go i would suggest checking measurements on everything first but i would agree that a shroud with mechanical fan would work better in this instance and would be cheaper for a temporary setup. Also a good coolant flush and new set of hoses and thermostat is realatively cheap about 40-50 bucks and will make a difference.
1962 Mercury Comet 170 ci, Dagenham Trans, 2.83:1 7.25 rear.
She ain't fast but she's fun. 8)
65coupei6
Assistant Admin
Post #8 by 65coupei6 » Wed Sep 19, 2018 2:57 pm
I have a AC fan with shroud. But, installed a small pusher that I grabbed from a Mazda 323 at my local junkyard. I have it hooked up to a derale temp. switch. So it comes on at a preset temp. But, it is also hooked up to a manual switch. So, I can turn it on if needed.
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
bmbm40
Post #9 by bmbm40 » Wed Sep 19, 2018 8:20 pm
There is a company called FlowKooler? I think. They used to list part numbers for high flow water pumps for the 144/170/200. But that shroud with the ac mechanical fan would be a good way to go. Your radiator might need a visit to a good radiator shop for cleaning out.
ags290
Post #10 by ags290 » Fri Sep 21, 2018 12:34 pm
I have the same setup that was mentioned earlier, the Ford A/C fan and Shroud and have not experiences any overheating issues. Ambient summer temperature in the Dallas area regularly passes 100 degrees.
Kevin
Early 1965 Mustang with a 170
gus91326
Post #11 by gus91326 » Fri Sep 21, 2018 1:01 pm
I have had a different experience. I have a breathed on 200. I added a V8 style aluminum radiator and added an electric fan on the engine side. The fan I got was a SPAL unit I purchased from the Fan Man; I called them and they advised me to order an 2.05" thick SPAL unit that was only $60. It pulls 1300cfm, and has worked in hot LA traffic with my engine with no issues.
https://the-fan-man.com/product/16-spal ... -fan-s400/
For power I have a 94 amp 3g alternator that works the fan, electric power steering, electric fuel pump, Fitech, headlights, wipers, etc. with no issues.
65coupei6
Assistant Admin
Post #12 by 65coupei6 » Fri Sep 21, 2018 7:49 pm
Is your electric fan always on? Or do you have a sensor that turns it on at a specific temp?
...Marco
gus91326
Post #13 by gus91326 » Sat Sep 22, 2018 12:31 am
65coupei6 wrote:Is your electric fan always on? Or do you have a sensor that turns it on at a specific temp?
Turns on at 195 and turns off at 185.
Users browsing this forum: No registered users and 9 guests
