Hi Folks,
I rebuilt my adjustable rocker assembly. New shaft (old one was very worn), removed all adjuster nuts and cleaned all oil passages. Also drilled out the valve oil passage to the handbook specs.
I was sharing this with another FordSix member who said the adjuster nuts are never to be removed all the way as they used a tapered locking thread. I always understood it as they were just interference fit. Did I just screw myself by trying to clean everything good and removing the nuts? I had to remove and replace one due to severe wear on the ball on the adjuster nut anyway.
Someone please tell me I didn’t mess up! Or if I did, it’s not that bad...
Cheers,
Matthew
Cheers,
Matthew
