2018 Contributors:
Autolite 2100 mixture screw snapped
StarDiero75
Post #1 by StarDiero75 » Mon Dec 24, 2018 1:13 am
Howdy guys,
I got an autolite 2100 off a 66 289 with a 1.08 venturi. The carb tag says its a 72 carb. But anyhow, everything was seized and i got it all working smoothly. I tried to remove one of the mixture screws and it snapped. The other one came out fine. I'll be using an easy out but i gotta buy one first.
My question is, does it share the same mixture screw as the autolite 1100? I'm having a hard time finding a screw with the same length. Mike Carbs has a 1.466" for the 2100 but mine is a little shorter than that. Is that ok? I just don't want to start buying things and not need them.
Thanks,
Ryan
--1965 Ranchero w/1966 200 and 3.03 column shift, 8" rear 2.8 (Yes I know the gearing sucks), 1968 1.08 Autolite 2100 with VI adapter, CRT Performance HEI.
CZLN6
Re: Autolite 2100 mixture screw snapped
Post #2 by CZLN6 » Tue Dec 25, 2018 11:40 am
Howdy Ryan:
Merry Christmas. That's a new one on me. I've looked at lots of mixture screws from both 1100s and 2100s individually as I rebuild each carb. I have never done a comparison. My first guess is probably not. I'm not at home now or I'd go do a comparison.
FYI- there is a stamped code on the foot (mounting hole part of the base). That code may help you when ordering and/or identifying what you have.
I'll be interested to know what you find out so let us know.
chad
alu screw snapped off in carb
Post #3 by chad » Tue Dec 25, 2018 2:24 pm
"... easy out..."
I don't recommend that product (last choice).
weld-a-nut or weld-a-stud is 1st in the list (even alu)...
Gota pic?
StarDiero75
Re: alu screw snapped off in carb
Post #4 by StarDiero75 » Wed Dec 26, 2018 2:21 am
chad wrote:"... easy out..."
Gota pic?
It broke flush with the carb. I don't have the equipment to even attempt anything other than the easy out. Next step would be to bring it to the machine shop
StarDiero75
Post #5 by StarDiero75 » Wed Dec 26, 2018 2:23 am
CZLN6 wrote:Howdy Ryan:
I'll check for the code, thanks!
Yeah I was just curious. I would think it could make finding a replacement screw easier
Will do!
chad
screw snapped in alu piece
Post #6 by chad » Wed Dec 26, 2018 1:30 pm
4 me that sz easy out just 'buggers' the whole thing up.
Just one guy's solution?: center punch, progressive drill sz to just below threads,
use pick to chip off thread chips frm wall's threads. Some times a re-tap to clean up.
sometimes for new bigger ID, sometimes none of this just exact same sz screw. The tig
(& mig) here can do alu & often a nut tacked thru its center to the broken stud duz it (Y?
cuz the heat of the weld loosens & the new nut is attached so a surface to wrench on).
Good Luck, I enjoy problem solving (& even "over engineering". I cut our cord wood use in 1/2
while keepin the same ambient temps buy futzin around w/'bosses' wood stove).
woodbutcher
Post #7 by woodbutcher » Thu Dec 27, 2018 1:10 pm
:hmmm: If you try the drill it out route,you might be well served to get a set of LEFT HAND drill bits.They might be a bit spendy,but can save a lot of headaches down the road.Any quality tool supplier should be able to supply them.
Good luck.Have fun.Be safe.
Leo
Otto von Bismarck
Econoline
Post #8 by Econoline » Fri Dec 28, 2018 2:16 am
The problem with drilling it out is that if you drill through you will ruin the carb You'll have to be very careful and mark the depth on the bit with some tape and only drill deep enough to get just past the threaded bit.
It ain't gonna fix itself
StarDiero75
Post #9 by StarDiero75 » Fri Dec 28, 2018 2:33 am
I picked up some screw extractors from Harbor Freight. I've never been in one before, i swear I'll go broke if i go back in there haha.
I'll give the small one a try on sunday probably. We shall see how it goes. I really dont want to toss the carb since its a 1.08. I hate having to buy more crap.
chad
screw extract, alu housing
Post #10 by chad » Fri Dec 28, 2018 12:56 pm
"...hate having to buy more crap..."
hear ya there. Also on a HF visit.
TOOLS aint crap, tho. All ways enjoy nother tool.
tack,
reverse drill bit,
progressive dia drill~
'easy out' 6th or 7th
drag-200stang
Post #11 by drag-200stang » Sat Dec 29, 2018 6:06 pm
Frankly I would just work around it...It may be perfect just as it is set.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
StarDiero75
Post #12 by StarDiero75 » Mon Dec 31, 2018 12:22 am
drag-200stang wrote:Frankly I would just work around it...It may be perfect just as it is set.
Its screwed in perty far. Im just gonna ditch it. Ive started hitting the carb body with the drill and i think its time to quit.
chad
autolite 2100 mixture screw snapped
Post #13 by chad » Mon Dec 31, 2018 8:09 am
sender my way
Users browsing this forum: No registered users and 18 guests
