Need to connect 5/16" steel line to a 3/8" NPT Fuel Regulator.
I want to connect the steel fuel line to the regulator without putting a hose in-between. I would like to put a flare on the steel lines with a pipe nut on the pipe.
The regulator does not have any pipe/flare connection. (see attached pics) So I need a 3/8" NPT (regulator side) to 5/16" female pipe connection that will handle flare.
I believe that the 3/8 NPT to the regulator needs an o-ring.
This is a carburetor system so low fuel pressure around 7psi.
I am just confused of what adapters to use to make this happen. I have searched the internet and performance parts sites... just confused on what to use.
Thanks,
K
Thanks,
K
