Rocker Arm Assembly Rebuild
Georgia200
Any videos on how to rebuild the assembly?
I have a new shaft and rockers, will reuse the pedestals and springs.
Specifically I need help on removing and installing the pedestals from the shaft.
On the shaft I disassembled I had to heat the pedestals, no way I was going to get them off otherwise.
The shaft I removed from my 250 is in rough shape, after soaking in degreaser for 2 weeks, nothing will budge.
Should the shaft spin in the pedestal or is there an interference fit?
They should slide freely. They get out round from being torqued down. Also be sure and debur the holes in the new shaft if needed.
they should slide off
I took a lill emery paper to mine
sent a gun brush down inside (its an oil passage).
I numbered then to go back where the came frm (o0OP thats the rockers which need all the nooks'n
crannies cleaned too)...
