Milling Head for 2bbl
StarDiero75
Re: Milling Head for Direct Mount (2bbl)
Post #51 by StarDiero75 » Fri May 03, 2019 1:15 pm
chad wrote:"...i used a 3/8 carbide end mill on a vertical mill at 500 RPM..."
4 lip (double end) end mill here. The 500 rpm seems slo but depends on speeds'n feeds (of course).
Some 'hand feed'. Others 'automatic table'.
I hand fed it. And mine was 4 flute. I was amazed at the surface finish, it was so smooth!
StarDiero75
Re: Milling Head for 2bbl
Post #52 by StarDiero75 » Thu May 09, 2019 3:57 am
Got the adapter angle milled today. I got it roughlt to 3.5°. It's definitely closer than it was flat milled. Next is to drill the holes into the head. I brought my junk valve cover to make sure it all fits on and allows me to take the VC off if needed.
Then i got to get studs and test fit the carb to make sure the butterflys move without obstruction. Im excited that its almost done!
What I'm happy about too is that its all documented here so others can see what I'm doing in stages so hopefully it makes it easier to see what is needed to be done.
Thanks guys for all the advice so far, keep it coming,
Ryan
StarDiero75
Post #53 by StarDiero75 » Wed May 15, 2019 12:09 am
I finally finished it guys. All thats left is filing a few spots that intrude on the intake area and sealing the surface in between. But I'll seal the surface after I get it magnafluxed and all the other head work to it.
Also i made a cover for the EGR valve spot. I'm thinking about drilling and tapping for a vacuum source there, or should i leave it as is? I don't really do anything for vacuum other PCV and my vacuum gauge. But i may add power brakes in the future, I'll decide that after i get my disks on.
So I've heard to use the aircraft grade permatex or to use 1/6" gasket material, i need to decide on that next. What is the poll on that?
Thanks,
Ryan
chad
Post #54 by chad » Wed May 15, 2019 11:25 am
that really takes the cake (proof is right beside !).
8^ )
I C in 1 pic another adapter below, yes?
Do U have a shot of that to look at?
Is top adapter so thick to get the carb links above the V/C?
Thanks for showin all the pic!.
Soldmy66
Post #55 by Soldmy66 » Wed May 15, 2019 12:43 pm
Please accept my praise of your efforts. Everything you've done looks great - and I hope it gave you a sense of accomplishment.
Well done.
StarDiero75
Post #56 by StarDiero75 » Wed May 15, 2019 1:07 pm
Soldmy66 wrote:Please accept my praise of your efforts. Everything you've done looks great - and I hope it gave you a sense of accomplishment.
Well done.
Thanks a lot man. My hands hurt and are coverned in aluminum. I now hate aluminum haha. But yes it feels amazign to have done it all. Thank you very much
StarDiero75
Post #57 by StarDiero75 » Wed May 15, 2019 1:11 pm
chad wrote:that really takes the cake proof is right beside !). 8^ )
IS whats shown so thick to get the carb links above the V/C?
Thanks for showin it all.
Haha i thought the cake was a nice touch lol.
The adapter below is my cover for the EGR spot since i wont be running that. If you really want to see that stand alone i can do that for you.
No it is not. The throttle linkage hits on the low side. I need a 1" spacer to clear the log. I ordered one off eBay even though i could make it, but its time i actually start doing the assignments in class instead of this haha.
Post #58 by bubba22349 » Wed May 15, 2019 2:22 pm
In your tuning experiments remember that on a street only car the EGR valve is quite useful in helping you to get the best in MPG. Plus since it's only operating at the higher hiway cruise speeds it doesn't really have an effect lower speed power. Good luck :thumbup: :nod:
StarDiero75
Post #59 by StarDiero75 » Wed May 15, 2019 4:18 pm
bubba22349 wrote:In your tuning experiments remember that on a street only car the EGR valve is quite useful in helping you to get the best in MPG. Plus since it's only operating at the higher hiway cruise speeds it doesn't really have an effect lower speed power. Good luck :thumbup: :nod:
I'll be using headers so i can't run one anyway.
Does the EGR not restrict and cause unnecessary backflow? I thought emissions crap usually reduced gas mileage
drag-200stang
Post #60 by drag-200stang » Wed May 15, 2019 4:26 pm
You have done a very nice job!
On the gasket thickness, the flatter the two surfaces are the thinner it can be , and the thicker you go the more distortion you can have when tightened down...How thick is the gasket between the carb base and the body of the carb...It should represent the adapter to manifold surface.
At the top edge of the adapter is it the same size as the carb bore or a touch larger and not smaller?
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
tdlund
Post #61 by tdlund » Wed May 15, 2019 5:27 pm
I love that you have a cake next to your head
chad
Post #62 by chad » Wed May 15, 2019 8:42 pm
look pretty busy.
"...If you really want to see that stand alone i can do that for you. ..."
no priority, but yeah, either that or a link to co who has a pic of it on their site~
Thnx
Econoline
Post #63 by Econoline » Wed May 15, 2019 9:16 pm
Hey Ryan, what's up with the plate you've got on there blocking the manifold port?
It ain't gonna fix itself
chad
milling head for direct mount 2v
Post #64 by chad » Wed May 15, 2019 9:50 pm
2X^^^^
he may send us a pic of it alone or alone mounted
StarDiero75
Post #65 by StarDiero75 » Wed May 15, 2019 11:17 pm
drag-200stang wrote:You have done a very nice job!
Thanks man!
So everything should be very flat. I ran the mill over all my machined surfaces real slow to geg them all real nice and smooth. So my gasket should be similar in thickness to the carb gasket?
The ends of the slot fit the carb perfectly. The width of the slot is slightly larger. Why?
StarDiero75
Post #66 by StarDiero75 » Wed May 15, 2019 11:18 pm
tdlund wrote:I love that you have a cake next to your head
Thats the only way to sweeten up the picture haha
StarDiero75
Post #67 by StarDiero75 » Wed May 15, 2019 11:21 pm
Econoline wrote:Hey Ryan, what's up with the plate you've got on there blocking the manifold port?
Thats a cover for the EGR port. I'll be running headers and so i wont be using it. I was thinking about drill and tapping it for a vacuum port but i dont have a tap for the vacuum fitting, or can I just use a normal tap? I believe the brass hose barbs are 1/4" NPT
StarDiero75
Re: milling head for direct mount 2v
Post #68 by StarDiero75 » Wed May 15, 2019 11:21 pm
chad wrote:2X^^^^
I'll send a pic later tonight or tomorrow
Econoline
Post #69 by Econoline » Thu May 16, 2019 3:21 am
Yeah 1/4 ntp pipe tap
drag-200stang
Post #70 by drag-200stang » Thu May 16, 2019 8:39 am
X2 .... Make sure that you get a couple fittings to test your fit as you go, it is easy to go too deep and be loose.
Do you guys know how I know that your priority's are messed up...I never saw the cake :lol:
66 Mustang Coupe
drag-200stang
Post #71 by drag-200stang » Thu May 16, 2019 9:25 am
Thanks man!
So everything should be very flat. I ran the mill over all my machined surfaces real slow to get them all real nice and smooth. So my gasket should be similar in thickness to the carb gasket?
Close but I was thinking of the gasket between the carb halves...Some carb to manifold gaskets can be a little too thick and that is when you find bent ears on the carb when over tightened...Really anything like that will be fine...
That will be just fine...If the hole in the adapter was smaller than the carb bore it would hurt flow and could be tapered.
66 Mustang Coupe
chad
rebuild'n mod a 200 for performance (MPGs & pep)
Post #72 by chad » Thu May 16, 2019 9:51 am
i have not read this just skimed the pic
http://www.agcoauto.com/content/news/p2_articleid/197
but we have covered it here several times (quicker to hit google
for me than use "Search" here).
Some restorers (read 'younger guys') were not around for the evolution of the system.
I C this and other engineered systems stripped off in their effort to customize their ride.
It may B better practice to research the motor function when completing their wrk. I will
assemble a 'closed PCV' system. I have 2nd thoughts with the 'adjustable' pcv (I believe it wuz)
Cat posted abt back awhile ago. I havea lill more cash for the project now and will B researchin it more.
:nod:
StarDiero75
Post #73 by StarDiero75 » Thu May 16, 2019 12:30 pm
Thanks man!
I know about bent ears, my 2100 had bent ears and i had to mill it flat. I mean i can look at getting a thinner material. I'll see what they have for gasket material. Otherwise I'll stick to the spacer to carb gasket thickness.
I made a big deal about the slot being the same size as the carb, or larger. I didn't want any restriction as the point of this conversion is to let the head breathe more. I have a couple of very small intrusions but I'll clean them up with a file.
Post #74 by bubba22349 » Fri May 17, 2019 6:57 pm
No the EGR doesn't restrict or cause un nessisary back flow. When you look at how its designed you can see it's not going cause a restriction, it introduces inert exhaust gas into the intake system only at steady state Cruising Speeds of 45 MPH or more this allows a leaner fuel mixture to save fuel. Yeah many people believe "emissions crap" lowers power and reduces Gas Milage this isn't nessisarly true especially for most street use cars. There is a level of all out high performance were it can start to be a henderace to power and of course there's the cosmetic looks. Good luck you are doing a great job on your build. :thumbup: :nod:
chad
hole covered on log below adapter
Post #75 by chad » Fri May 17, 2019 7:02 pm
this comes frm crankcase so even less (positive crankcase ventilation, not exh gas recirc)
Users browsing this forum: powerband and 25 guests
