Hi All,
I'm compiling all my parts for rebuilding the short block and I wanted to see if I have the complete list of gaskets. There are multiple kits out there (Fel-Pro has 2, Mahle, VI, etc) and none of them contain a complete list of all componenets. The manufacturers pages don't list them either. I have a few of the gaskets already, so I don't need the full kit.
Can anyone fill in the blanks of what I might be missing? (note, this is only for the block and not the head):
Rear Main Seal
Fuel Pump to Block
Timing Cover
Water Pump
Thermostat Housing
Oil Pan Sides and Rear
Oil Pan Drain Plug
Oil Pickup Tube to Pump
Oil Pump to block (Does this exist even? Not sure if this is a real thing)
Is there one for the dizzy to block (o-ring?)
Any others I'm missing for the block only?
Cheers,
Matthew
Rear Main Seal
Fuel Pump to Block
Timing Cover
Water Pump
Thermostat Housing
Oil Pan Drain Plug
Cheers,
Matthew
