<<< New Site Update >>>
Will this work for my 63 Falcon
rzcrisis
Post #1 by rzcrisis » Sat May 25, 2019 10:12 pm
Found this 200CI on kijiji here in Canada that sounds good to swap in place of my 144CI in my 63 Falcon. I have a spare auto column and brake pedal assembly to use to replace my 2.77 manual OTT. Waiting on some question responses from poster regarding tranny but do you think this would be a relatively simple swap out? See link below.
Thanks for your info.
Randy
https://www.kijiji.ca/v-classic-cars/os ... cale=en_CA
Plan the Work, Work the Plan.
1963 Ford Falcon 2DR Sedan/144ci/3Spd -work in progress (Canadian Survivor)
1964 Ford Thunderbird 2DR HT/390ci/Auto -fully restored ("Thelma"-our California girl)
Max_Effort
Re: Will this work for my 63 Falcon
Post #2 by Max_Effort » Sat May 25, 2019 11:04 pm
I think it will perform better with the 3 speed (or a 4 speed)
Post #3 by bubba22349 » Sat May 25, 2019 11:06 pm
HI Randy, that engine would be almost a direct bolt in swap. It's a 1966 or maybe an early 1967 so that's great there will be some minor differences such as the better Alternator vers your current generator system. This will need a little wire change but maybe the harness comes with the engine. Good luck :thumbup: :nod:
drag-200stang
Post #4 by drag-200stang » Sat May 25, 2019 11:47 pm
The block looks like a 170 to me, better check that out.
The block looks just like a 1970 170 I have but cannot see the intake well enough to tell what the head is.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
Econoline
Post #5 by Econoline » Sun May 26, 2019 1:12 am
Good call. That does look like a 170, not a 66 or 67 200 for sure. Note the 3 core plugs instead of five.
It ain't gonna fix itself
lavron
Post #6 by lavron » Sun May 26, 2019 1:15 am
A C8DE block with 3 freeze plugs is a 170 not a 200.
See Ya,
Mike
64 Comet 202 Sedan, 250- I6, Air Ride, Mll, 8.8 LSD, 4 wheel Discs
Currently a Build in Progress- Whatever I do it will be awesome!
rzcrisis
Post #7 by rzcrisis » Sun May 26, 2019 9:51 am
Good call on the freeze plugs....I should have caught that (read the performance handbook enough!). Guess I got excited as it was one that is not too far from me. The guy emailed me back and said the bell housing mates to a c4 but I will email him back and tell him what he actually has.
Randy
Users browsing this forum: bmbm40 and 19 guests
