2018 Contributors:
250 Engine Length?
GreasyNRusty
250 Engine Length?
Post #1 by GreasyNRusty » Mon Jun 03, 2019 3:19 pm
Kinda got the hots to build a 250...but the project I have in mind for it requires an inline four or a (yuck) 60-degree (puke) V-6 :tabu: .
The kit roadster was designed around a Ford 2300, which is approximately 23", front of single-groove crank pulley to bellhousing flange at back of block.
I'm wondering if someone could provide a similar length measurement, front of 3-groove crank pulley-to-bellhousing flange for a 250?
Thanks, Eddie
2000 Pontiac Grand Prix GTP, 3" Blower Pulley, Headers
1991 F-150, 5.9 Cummins, A/A .73 O/D, T-19 4-spd., 3.07 (!)
1962 Royal Enfield "Constellation"
lavron
Re: 250 Engine Length?
Post #2 by lavron » Mon Jun 03, 2019 5:22 pm
Well mine is off at the machine shop but if you can figure out how long a 200 is the 250 is about 1" longer due to the length of the water pump, I guess I am not much help there but someone will have exact specs I am sure.
The 200 and 250 are the same length however minus the accessories on the front.
See Ya,
Mike
64 Comet 202 Sedan, 250- I6, Air Ride, Mll, 8.8 LSD, 4 wheel Discs
Currently a Build in Progress- Whatever I do it will be awesome!
chad
250 Engine Length?
Post #3 by chad » Mon Jun 03, 2019 5:35 pm
"...Ford 2300..."
Plez don't kick the 23 or 2500 Lima or pinto engine.
See MechRick's mods:
https://fordsix.com/viewtopic.php?f=13&t=72863
"D" shaped heads do it...
:thumbup:
Post #4 by xctasy » Tue Jun 04, 2019 2:29 am
Great Bloke is da man, aka gb500.
See this in viewtopic.php?f=1&t=77062&p=593124#p593124.
31.5 inches for the 250, 29.5 for the 200.
Australians had an intermediate 3.1 liter and 3.6 liter block 8.425" tall in 188 and 221 cubic inches, and a destroked 250 with a taller 9.38" block in 200 cubic inch form.
US and Australian 144, 170 and 200 had 7.830" or so tall blocks from the crank centerline to the base of the head face.
GreasyNRusty
Post #5 by GreasyNRusty » Tue Jun 04, 2019 1:00 pm
xctasy wrote:...See this in viewtopic.php?f=1&t=77062&p=593124#p593124.
31.5 inches for the 250, 29.5 for the 200...
THANK YOU indeed!
No disrespect for the 2300, either! The 2300 motor was my first choice and then I missed on a sorta-virginal '73 pulled from a '73 Pinto in 1975 for installation in a Model A, then put into storage; the kid inherited it, and...
...The extra length measurements of both 200 and 250 sixes over the 2300 four are useful to me; there is a frame stretch involved, no big deal mechanically but the extra length has to added between firewall and radius rod and accounted for in a stretch of the hood sheet metal.
I am curious if the extra hood length (hood length per kit, 31.5"; 250 +8.5" or 200 +6.5", i.e., 40" or 38") would throw the proportions off; the car involved is a Speedway Motors Track-T "kit" car, seen here: https://www.speedwaymotors.com/Speedway ... ,4010.html.
Please look beyond that horrible wheel/tire combination :shockin: (or, for true masochism, imagine that exact car built with separate freestanding RECTANGULAR headlights :boom: I have blackmail pics from '85, the horror, the horror).
Eddie
lavron
Post #6 by lavron » Tue Jun 04, 2019 5:43 pm
That is cool, are you going to be ok height wise? I guess the Pinto motor is fairly tall anyway with the overhead cam.
See Ya,
Mike
mustang6
Post #7 by mustang6 » Mon Jun 10, 2019 2:07 am
It is cool, I wonder why a modern kit car still uses '49-54 Chevy spindles?
Scott
Post #8 by xctasy » Mon Jun 10, 2019 2:41 am
mustang6 wrote:It is cool, I wonder why a modern kit car still uses '49-54 Chevy spindles?
Wheel height, type and size. The whole package was the base for the early Corvette.
Users browsing this forum: No registered users and 16 guests
