<<< New Site Update >>>
Should I Use a Billet Flywheel?
StarDiero75
Post #1 by StarDiero75 » Thu Jun 06, 2019 12:52 pm
Howdy Guys,
So I'm just about done gathering everything I need for the T5 swap, I bought a modern driveline dual friction diaphram 9" clutch and billet flywheel for the cost of just the clutch. They're balanced together as well. But should I run the billet flywheel or the stock flywheel with my current setup?
4cyl turbo T5 4.03 1st and .81 5th
2.8 8" rear
P215 tires (soon to be P225)
The engine will be beefed a bit too with the 2V 1980 head, 1.5" exhaust valve, dual out VI headers 2" pipes, and a 256/256 .420 lift 112 lobe sep.
I have heard I should have a stock flywheel with the 2.8 rear, but i figured the extra engine mods might help with it.
Opinions?
Thanks
Ryan
CNC-Dude
Re: Should I Use a Billet Flywheel?
Post #2 by CNC-Dude » Thu Jun 06, 2019 3:40 pm
Since its already balanced, there isn't any reason you shouldn't go ahead and use it.
StarDiero75
Post #3 by StarDiero75 » Thu Jun 06, 2019 4:14 pm
CNC-Dude wrote:Since its already balanced, there isn't any reason you shouldn't go ahead and use it.
Thats what i figured. Just got it today and it looks great. Can't wait to slap it on
gb500
Post #4 by gb500 » Thu Jun 06, 2019 6:11 pm
A picture is worth a thousand words and all that ….:)
StarDiero75
Post #5 by StarDiero75 » Fri Jun 07, 2019 3:58 am
This is what i got. The sharpy mark is how i am to install the clutch on it.
Here is the pressure plate as well
drag-200stang
Post #6 by drag-200stang » Fri Jun 07, 2019 9:15 am
Looks good Star.
Can you show us the back side ?
I have not seen a 200 flywheel come apart, the billet it is a smart thing to do.
I have typed about this before,I had two oem strong tuff man pressure plates come apart...No part of the pp or the bell housing found larger than 1'', blew off block and trans mounts, cut off the starter nose, severed one header tube, put cuts in floor...this happened at the 7000 range...No good rev limiters at that time.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
StarDiero75
Post #7 by StarDiero75 » Fri Jun 07, 2019 11:33 pm
drag-200stang wrote:Looks good Star.
Yeah I'll post a back side picture probably tomorrow night!
Thats nuts man, thats why they invented the scatter shield lol. But no one makes one for our engines right?
gb500
Post #8 by gb500 » Sat Jun 08, 2019 4:29 am
thanks
lavron
Post #9 by lavron » Sat Jun 08, 2019 8:15 am
StarDiero75 wrote:Thats nuts man, thats why they invented the scatter shield lol. But no one makes one for our engines right?
Modern driveline mentions one in the section on cable clutch conversions (Quicktime MD-401-8050) but I can't find it for sale.
See Ya,
Mike
64 Comet 202 Sedan, 250- I6, Air Ride, Mll, 8.8 LSD, 4 wheel Discs
Currently a Build in Progress- Whatever I do it will be awesome!
drag-200stang
Post #10 by drag-200stang » Sat Jun 08, 2019 9:48 am
I think that materials are better today, and with a hyd. cam it will not rev high enough to be a problem ... Rev limiters are cheap enough no reason not to have the added safety.
I think that you will be fine.
66 Mustang Coupe
chad
Post #11 by chad » Mon Jun 10, 2019 2:46 pm
Mike-
for the Quicktime MD-401-8050 -
Modern Driveline sez:
"...250 motor
303 transmission
Desired transmission: T5z Drive '93 or earlier, Ford Motorsport
Note: the requested bell, MD-401-8050 with either a 7 or 9 o'clock for position is available but will not fit the above block.
This quote is based on using the existing bell housing with an adapter, the 157 tooth 10" clutch pattern flywheel. and mechanical clutch linkage. Hydraulic clutch release is available.
T-5z, 93 and earlier, Ford motorsport
2.95, 1.94,1.34,1, .63 od mechanical speedo (Torque rated for 330ft/lbs, 1 year warranty from the date of use)
* Quik Stik Shifter, Ford T-5/T-45, 1" back ($255)
Adapter plate Assy., T-5, Ford Wide pattern SBF/BBF & 1967 and later 200ci, 1983-93 Ford T-5 (SROD bell to 94-04 T-5)
Clutch Set, Organic 10" 10 spline 1-1/16", Mech T/O bearing, pilot, alignment tool. (1 year warranty!" ($175)..."
StarDiero75
Post #12 by StarDiero75 » Wed Jun 12, 2019 7:20 pm
Back shot
drag-200stang
Post #13 by drag-200stang » Wed Jun 12, 2019 10:59 pm
Good man. :thumbup:
66 Mustang Coupe
drag-200stang
Post #14 by drag-200stang » Wed Jun 12, 2019 11:39 pm
See Ya,
Mike
Its hard to find anything on their site, but somehow I found a quick time for a 200 high mount 136 t flywheel with a MD 401-4050 part number at 768.95 $
66 Mustang Coupe
lavron
Post #15 by lavron » Thu Jun 13, 2019 1:24 am
drag-200stang wrote:I found a quick time for a 200 high mount 136 t flywheel with a MD 401-4050 part number at 768.95 $
Ouch! I am glad I don't need one, I like trying to do stuff cheap myself :roll:
See Ya,
Mike
StarDiero75
Post #16 by StarDiero75 » Thu Jun 13, 2019 1:14 pm
I got a deal on mine. With their dual friction clutch, diaphram style, and all mounting hardware, + flywheel, all balanced together, cost me $360. I made out like a bandit
wsa111
FSP Moderator
Post #17 by wsa111 » Thu Jun 13, 2019 7:45 pm
Don't forget to put sealer on the bolts to flywheel to crank threads.
Econoline
Post #18 by Econoline » Thu Jun 13, 2019 9:36 pm
wsa111 wrote:Don't forget to put sealer on the bolts to flywheel to crank threads.
+ :thumbup:
It ain't gonna fix itself
Users browsing this forum: No registered users and 14 guests
