<<< New Site Update >>>
Valve train clatter
charliecurrie
Valve train clatter
Post #1 by charliecurrie » Sat Jun 08, 2019 9:08 am
Just installed 264/274 112 cam from Vintage Inlines and I can't get the valve/rocker adjustment correct - quiet.
Stock '66 200.
Rebuilt '66 head
Adjustable rocker assembly
302 valve springs
New Sealed Power hydraulic lifters
Stock pushrods - ~8"
If I adjust the valves according to the CI tech recommendation the valves hang open.
If I back the adjustment off until I get maximum vacuum and smooth idle, it clacks and taps annoyingly loud.
Suggestions?
wsa111
FSP Moderator
Re: Valve train clatter
Post #2 by wsa111 » Sat Jun 08, 2019 12:27 pm
charliecurrie
Post #3 by charliecurrie » Sat Jun 08, 2019 2:42 pm
I can't get close to zero lash without the valves hanging open. It creates a huge vacuum leak and uneven / surging idle.
If they're not clacking / ticking they're not closing.
When everything is lose and noisy, I have 20+ in of vacuum and a rock steady needle on the gauge and a rock steady idle at 500 rpm in neutral.
My rockers are the shaft mounted non-roller. This valve train worked fine with the stock 53 year old cam and lifters. Well fine for its age and worn lobe the fuel pump lever rides on and a couple of lazy lifters.
Econoline
Post #4 by Econoline » Sat Jun 08, 2019 2:59 pm
Have you tried to isolate the problem to a single valve/lifter? Do all the lifters depress?
It ain't gonna fix itself
charliecurrie
Post #5 by charliecurrie » Sat Jun 08, 2019 3:20 pm
It's every cylinder, every valve...so, I suppose, every lifter.
Is it possible none of the lifters are depressing? Although, my buddy who helped with the install, depressed one of them for no reason before I put it in.
Econoline
Post #6 by Econoline » Sat Jun 08, 2019 3:33 pm
What are you using for springs? What is the closed pressure?
charliecurrie
Post #7 by charliecurrie » Sat Jun 08, 2019 4:21 pm
302 - 71 lbs
Started with stock 200 springs. The 302 springs didn't change anything.
wsa111
FSP Moderator
Post #8 by wsa111 » Sat Jun 08, 2019 10:13 pm
How is your oil pressure???
Your valve springs are not involved with this condition, but you need close to 100# seat pressure.
Sometimes it takes several minutes to have the hydraulic lifters to respond to a half turn of adjustment from zero adjustment.
charliecurrie
Post #9 by charliecurrie » Sat Jun 08, 2019 11:47 pm
Oil pressure is good - no gauge - but the light doesn't come on. And, there's plenty of oil flow to the valve train - easy to see with the valve cover off.
Oh, we've run it longer than several minutes and the valves never close completely. But, as soon as you start backing off the adjusters you can see - vacuum gauge and tac - and hear and feel the improvement. We do the adjustment with the engine running.
All I changed was the cam, lifters, valve springs and timing set. Didn't have this problem before the change.
It runs down the road just fine. A noticeable improvement. Idles smooth at 500 rpm in gear.
pmuller9
Post #10 by pmuller9 » Sun Jun 09, 2019 9:23 am
Take each cylinder one at a time starting with #1
Turn the crank clockwise until the EXHAUST valve just begins to open and stop. Then adjust the INTAKE valve with 1/2 turn past zero lash.
Now turn the crank clockwise again till the INTAKE valve opens and begins to close. Just as the intake valve closes stop and adjust the EXHAUST valve with 1/2 turn past zero lash.
Continue the process on remaining cylinders 2,3,4,5 and 6
Zero lash is when you no longer have rocker movement by hand and you can feel the pushrod starting to press down on the lifter plunger.
wsa111
FSP Moderator
Post #11 by wsa111 » Sun Jun 09, 2019 10:02 am
This is a wild guess, but is it possible all the lifter plungers are bottomed out & the lifter plunger has not pumped up to the snap ring.
Take the rocker arm assy off the head.
Remove the distributor & with a drill spin the oil pump shaft to get line pressure. That will get the plungers to the top of travel.
Reinstall rockers assy with the adjusters backed off & adjust each valve. Good luck.
charliecurrie
Post #12 by charliecurrie » Sun Jun 09, 2019 10:14 am
Like I've said above, this has been done - multiple times using this and other procedures which produce the same final setting. And, the adjustment at zero lash, or zero lash plus, hangs the valves open - all of them.
This is not the first time I've adjusted the valves on this car - two engines and two different head and valve train configurations - never have had a problem...until now.
charliecurrie
Post #13 by charliecurrie » Sun Jun 09, 2019 10:30 am
wsa111 wrote:This is a wild guess, but is it possible all the lifter plungers are bottomed out & the lifter plunger has not pumped up to the snap ring.
Thanks - appreciate your continued input.
drag-200stang
Post #14 by drag-200stang » Sun Jun 09, 2019 11:03 am
Did you degree the cam ?
Is the cam spacer on the cam behind the pin with the inside bevel toward the journal, not to be confused with the cam retainer ?
Is it possible that the valves are closing and the the cam duration is making lower vacuum and rougher idle than you expected ?
Loose lash will get better vacuum and better idle because it cuts down on duration, cannot run it that way .
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
charliecurrie
Post #15 by charliecurrie » Sun Jun 09, 2019 1:11 pm
drag-200stang wrote:Did you degree the cam ?
All good questions. Thanks.
At this point, I have no other option than to pull it apart, inspect everything and put it back together.
charliecurrie
Post #16 by charliecurrie » Wed Jun 19, 2019 12:36 am
Update:
Replaced adjustable rocker assembly with non-adjustable rockers and push rods. Obviously, it quieted down, but ran like crap. Neutral idle was ok but in gear it was making some odd noises and idled ruff. Vacuum was lower also.
Had to put the adjustable rockers back on and put up with the clatter.
I'm thinking it has something to do with the lifters. Thinking I'll replace them and put in the stock cam I have on the shelf.
pmuller9
Post #17 by pmuller9 » Wed Jun 19, 2019 8:47 am
It looks like the lifters are not bleeding down after adjustment.
They are acting like solid lifters.
Take one out and see if you can push the plunger down away form the retaining clip.
If so measure how much travel you have.
Most anti pump lifters only have about .100" worth of travel.
charliecurrie
Post #18 by charliecurrie » Wed Jun 19, 2019 9:09 am
pmuller9 wrote:It looks like the lifters are not bleeding down after adjustment.
That's been my suspicion.
What would cause them to act like that?
pmuller9
Post #19 by pmuller9 » Wed Jun 19, 2019 9:19 am
I don't know why.
I'm hoping you find the reason when you take one out for inspection.
Econoline
Post #20 by Econoline » Wed Jun 19, 2019 11:28 am
Can you depress the lifters? Is it possible that when installed the lifters were fully pumped to the top and can't bleed down now?
charliecurrie
Post #21 by charliecurrie » Wed Jun 19, 2019 1:56 pm
Econoline wrote:Can you depress the lifters? Is it possible that when installed the lifters were fully pumped to the top and can't bleed down now?
During the first couple of times I tried to adjust the rockers, as I would tighten them to zero lash and stop, a couple of the lifters would sink enough for the rod to become loose enough to twist. But, only a couple, not all.
I tried depressing them yesterday when the rocker assembly was off and they didn't seem to move at all.
I'll have to pull the head and remove them to really be certain.
Post #22 by bubba22349 » Wed Jun 19, 2019 2:47 pm
It’s not as easy and a bit messy but before you pull it apart why not try adjusting them with the engine running. Loosen til they tick snug til they stop then go 1/4 turn more. Good luck :thumbup: :nod:
frozenrabbit
Post #23 by frozenrabbit » Wed Jun 19, 2019 5:12 pm
Are you measuring your lash adjustment or doing zero lash and half a turn?
I do a collapsed lifter lash. Holding the lifter compressed and measuring between the rocker and valve stem.
Ford manual for '63 shows 0.067"-0.200" lash for hydraulic lifers. Of course for OEM lifters. I shoot for the middle.
Maybe an issue with those Sealed Power lifters?
pmuller9
Post #24 by pmuller9 » Wed Jun 19, 2019 5:35 pm
charliecurrie wrote:During the first couple of times I tried to adjust the rockers, as I would tighten them to zero lash and stop, a couple of the lifters would sink enough for the rod to become loose enough to twist.
This may be the problem.
That is not zero lash!
Zero lash is when the pushrod barely begins to get tight and the lifter plunger is NOT depressed.
Then you go another 1/2 turn from there and the lifter plunger depresses about .050"
Did I read you correctly?
charliecurrie
Post #25 by charliecurrie » Wed Jun 19, 2019 11:41 pm
I did it like you stated. The plunger appeared to depress after i came to zero lash.
charliecurrie
Post #26 by charliecurrie » Wed Jun 19, 2019 11:44 pm
frozenrabbit wrote:Are you measuring your lash adjustment or doing zero lash and half a turn?
The initial adjustment was 0 + 1/2. Valves hung open.
charliecurrie
Post #27 by charliecurrie » Wed Jun 19, 2019 11:47 pm
bubba22349 wrote:It’s not as easy and a bit messy but before you pull it apart why not try adjusting them with the engine running. Loosen til they tick snug til they stop then go 1/4 turn more. Good luck :thumbup: :nod:
Adjusting with the engine running was the only way to figure out when the valves were actually closed - steady idle and steady vacuum needle. However, ended up with a very loose and noisy valve train.
pmuller9
Post #28 by pmuller9 » Wed Jun 19, 2019 11:57 pm
charliecurrie wrote:I did it like you stated. The plunger appeared to depress after i came to zero lash.
Then it looks like the lifter is collapsed.
There should be a spring under the plunger that keeps it up against the retaining clip.
The lifters have a problem.
charliecurrie
Post #29 by charliecurrie » Thu Jun 20, 2019 12:32 am
Yeah, the lifters certainly seem to be the problem.
Post #30 by bubba22349 » Thu Jun 20, 2019 10:02 am
Update:
Ok great now what's the condition of the adjustable rocker assembly? Dose the shaft show any signs of wear under each of rocker arms position, and or for the rocker arm bushings? The Info stated from your above update leads me to believe that the adjustable set of rockers may have quite a bit of wear in them compared to the non adjustable set. Good luck :thumbup: :nod:
drag-200stang
Post #31 by drag-200stang » Thu Jun 20, 2019 11:27 am
Yes they are good questions and the first two must be done but the third is not important or you could be chasing your tail.
If you take out the lifters they should be put back in the same place that they where broke in at.
New cams should be lubed with brake in lube paste on the lifter face and cam lobes and ran at 2000 rpm for 20 minutes with no idling.
I have no experience with hyd. lifters so I cannot help there.
66 Mustang Coupe
wsa111
FSP Moderator
Post #32 by wsa111 » Thu Jun 20, 2019 2:24 pm
I would put an oil pressure gauge in to see your oil pressure.
If low there maybe a front lifter galley plug that popped out????
drag-200stang
Post #33 by drag-200stang » Thu Jun 20, 2019 3:09 pm
wsa111 wrote:I would put an oil pressure gauge in to see your oil pressure.
X2 :thumbup: Could be temporary and taped where it can be seen.
66 Mustang Coupe
charliecurrie
Post #34 by charliecurrie » Thu Jun 20, 2019 6:12 pm
Update:
The adjustable rockers were on this engine (and a previous one) before the new cam was installed and worked just fine.
charliecurrie
Post #35 by charliecurrie » Thu Jun 20, 2019 6:20 pm
Answer to question one - no.
...two - yes.
...three - no.
The cam was broke in as you stated.
charliecurrie
Post #36 by charliecurrie » Thu Jun 20, 2019 6:26 pm
I've never had an oil pressure issue with this engine and the last time I put a gauge on it it was over 40 at idle - of course that doesn't mean it still is. However, there is so much oil passing over the valve train I have to cover the plug wires to keep them from getting soaked. Made the mistake of running the rpm to around 3k - it was a gusher.
Also, the idiot light hasn't come on and I know it works from past experience.
Econoline
Post #37 by Econoline » Thu Jun 20, 2019 9:01 pm
charliecurrie
Post #38 by charliecurrie » Fri Jun 21, 2019 12:16 pm
Econoline wrote:I came across a good article related to this on Dragzine.com
https://www.dragzine.com/tech-stories/pumping-up-is-hydraulic-lifter-pump-up-a-real-problem-today/
Thanks for that. Very interesting.
I ordered new lifters last night. We shall see...
charliecurrie
Post #39 by charliecurrie » Sat Jun 29, 2019 11:33 pm
Final Update: Never was able to figure out why I was having so much trouble getting the valve train to function properly. Took it all apart yesterday and inspected every part and how it was installed. Everything looked fine and was installed properly.
Reassembled it with new stock cam that I had on the shelf for five or six years. Put in new lifters - same brand as before - Engine Tech. Engine ran smooth and quiet from first fire. Ran it 2000 or so rpm - no tach, just by ear - for 20 minutes. Buttoned it up and went to dinner.
Took the wife to lunch and ran errands this afternoon - car never ran this good - she was impressed...I call that a win.
Thanks for all the input and suggestions - I really appreciate it.
Econoline
Post #40 by Econoline » Sun Jun 30, 2019 12:23 am
:thumbup: So what do you think, cam lift?
charliecurrie
Post #41 by charliecurrie » Sun Jun 30, 2019 9:07 am
Econoline wrote::thumbup: So what do you think, cam lift?
Really don't know. It was the mildest performance cam Vintage Inlines sells for use with an auto trans. So, there shouldn't have been a problem.
I'm suspecting something to do with the lifters. I was told and read to soak them overnight in oil - which I did. This time I washed them off with mineral spirits and then pumped them with oil prior to installation. Seems to have worked. But, I don't know.
chad
valve train clatter gone w/new install
Post #42 by chad » Sun Jun 30, 2019 9:22 am
thnx 4 da update CC.
Time will tell, eh?
Wonder what a new set of lifers w/the ol cam woulda done?
(U were thinkin 1 collapsed lifter?)
Best goin forward frm here !
:thumbup:
charliecurrie
Re: valve train clatter gone w/new install
Post #43 by charliecurrie » Sun Jun 30, 2019 10:32 am
chad wrote:thnx 4 da update CC.
Time will tell, eh?
:thumbup:
New lifters with the performance cam may have worked, but I didn't want to waste the lifters if it didn't - plus having to pull the head again.
Thanks and best to you also.
Post #44 by bubba22349 » Sun Jun 30, 2019 11:31 pm
:beer: Congrats on getting the cam and or lifter problems fixed. :thumbup: :nod:
charliecurrie
Post #45 by charliecurrie » Mon Jul 01, 2019 5:24 pm
bubba22349 wrote::beer: Congrats on getting the cam and or lifter problems fixed. :thumbup: :nod:
Thanks.
wsa111
FSP Moderator
Post #46 by wsa111 » Mon Jul 01, 2019 8:43 pm
What cam did you go with?? I'm glad the second time was a charm.
JackFish
Post #47 by JackFish » Mon Jul 01, 2019 10:56 pm
I was wondering if it might be a pushrod issue.
Did you go from a stock head gasket to a newer thicker style?
Was the head milled?
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
Econoline
Post #48 by Econoline » Mon Jul 01, 2019 11:25 pm
I was wondering if it was some kind of factory oil stuck/varnished into the lifters. I wish you'd just swapped them out but I completely understand why you swapped them both.
charliecurrie
Post #49 by charliecurrie » Tue Jul 02, 2019 11:12 pm
wsa111 wrote:What cam did you go with?? I'm glad the second time was a charm.
Pure stock.
charliecurrie
Post #50 by charliecurrie » Tue Jul 02, 2019 11:32 pm
JackFish wrote:I was wondering if it might be a pushrod issue.
I'm using the same pushrods I've been using with the adjustable rockers before and after the cam swap.
This engine - up until the cam swap - was factory stock. It had never been apart for any reason. It came out of a 66 Mustang with 60k miles on it. The cam and lifters were getting tired so I swapped out the original rocker assembly with an adjustable assembly hoping to give it a little more life.
In the process of swapping the cam, I replaced the head with a rebuilt head that was on the engine in the car when I bought it. The head appears to have been surfaced, but not shaved. I replaced the original metal head gasket with a Felpro.
Users browsing this forum: No registered users and 13 guests
