Cam Kits
Georgia200
Cam Kits
Post #1 by Georgia200 » Sun Sep 08, 2019 3:34 pm
Im cam shopping.
Im thinking Comp Cams K65-236-4 kit.
Im guessing that I can use this on a 250 except for the timing chain.
https://www.summitracing.com/ga/parts/c ... /overview/
chad
What Cam to Get ?
Post #2 by chad » Sun Sep 08, 2019 3:49 pm
Y choose that one?
What will ur compression B?
What will 80% of the driving RPM be?
What octane gas?
WHat is the specific driving application/condition/need?
Many of us get a '69 - '71 chain/gear for our 250 and retard 4*
for low rev oomph...
B RON CO
Re: Cam Kits
Post #3 by B RON CO » Tue Sep 10, 2019 8:42 am
Hi, I got the comp cam 252H. I am happy with it, but I also got a 2 barrel carb and now my engine can breath.
It is much better than the old Crane cam from the 90's, but probably too mellow for many guys. I have a 66 Bronco and I don't go over 4200 RPM.
The timing chain set it WRONG for the engine so you MUST degree the cam and use the timing chain set from Vintage Inline.
Good luck
1966 Ford Mustang - 289 V8
wsa111
FSP Moderator
Re: What Cam to Get ?
Post #4 by wsa111 » Wed Sep 11, 2019 5:03 pm
chad wrote:Y choose that one?
What octane gas?
Chad to get more low end you advance the camshaft.
Call Jerry at Schneider Cams & he will advise you on the proper camshaft for you six.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
chad
Cam Kits
Post #5 by chad » Wed Sep 11, 2019 6:07 pm
"...advance the camshaft..."
correct !
"...Many of us get a '69 - '71 chain/gear for our 250 and retard 4*..."
incorrect !
gettin tired here
:arrow:
All Ways degree any set U start w/new...
wsa111
FSP Moderator
Re: Cam Kits
Post #6 by wsa111 » Wed Sep 11, 2019 7:34 pm
What ever cam you get degree it in.
Schneider comes close to straight up.
Clay Smith cams come straight up.
Comp Cams come 4 degrees advanced. The 250H & the 260H are an antiquated profile.
Stock Ford cams are antiquated junk.
Users browsing this forum: No registered users and 15 guests
