Dragonlich1961
Been looking at possibly adding a header to my 61. It's a 200 with comp cam 260h, Weber 32/36 and 78 head with a bill recurved (wsa111) ds2 dizzy. Right around 9-9.2 compression. Backed by a V8 t5 and 3.73 8.8 axle.
Engine is being test fit this week to fabricate trans crossmember and clerence bellhousing to firewall due to large 9 inch bell.
I know the early falcons always have fitment issues due to being the smallest engine Ford produced, and. Never being intended for a V8.
Things to keep in mind, v8 steering, ac from vintage air (bracket is similar in style to one pictured in classic inlines archieve), unwilling to beat on sheet metal to fit if visable and not hanging low.
And recommended pipe size, I was thinking 2.25. I want single exhaust not duals
I will be installing global west subframe connectors, and these will be adapted for use as the trans cross member mount point due to me have a 1960 style chassis, no welded crossmember to floor with drop out section.
I want the sound level to be quiet but not catilac quiet. Some noise but not exsesive.
