‘74 250 - camshaft gear bolt
62Ranchero200
Pulling my cam to replace with a higher performance one. The camshaft gear bolt is something unusual, either a 12 point or a Torx head bolt, about 12 mm / 7/16 - is that oem? If not, it seems that my machine shop got creative or just used what they had in their toolbox when they installed it.
Bob
Bob, The Ford oem bolts were an interference fit. Use the same bolt, but use red locktite when installing. I believe it required 70 FT pounds of torque.
Hi Bill,
Thanks for the information. I finally got it out, it seems like a 7/16” NC. But is the 12 point 11 mm head oem?
Bob
"...11 mm head..."
no mm ona USA in dat yr - rusty...rounded over...?
I believe its 5/8" wrench 6 point.
