The Wife and I Just picked up the engine . Done Deal . Headed back home . Will post picks soon
chad":3jtmdezi said:may B ck the snout length on the W.pump? I gota GMB for my (non-Oz) 250 ina bronk and it looks shorter.
If U want give me the number, meanwhile I may B able to find mine (part #) altho it's beena yr...
bubba22349":34730211 said:So you might want to measure the top of piston to get the block deck height measurement, looks close to a zero deck height. The bore size think you said .040 ove so 3.720, next also CC the heads combustion chambers togeather with that info and head gasket thickness (looks like maybe has the Victor head gasket if so that's .044) now you can calculate the Static Compression ratio. Next you can check the cam timing events with a degree wheel and dial indicator and you can calculate the Dynamic CR. Good luck
