Water Pump/Fan Pulley 1970 Maverick 170 ci
Wascator
Active member
Hi, need a single-groove fan pulley for my engine; looking on Ebay there are at least three obviously different pulleys, all claiming to be for this engine. How can I identify the correct one? This is a base car no air no power steering, etc. with single-groove pulley on the crank. They seem to have different depths and diameters.
stating accessories would help. (see below chart) C4GE & CODE look good 2 me...
"...The stock three bolt pulleys for all small sixes from '63 to '77 measure 5 7/8" across. IDK if the pre-'63 144s are the same. All will be short snout water pumps so alignment should not be a problem. Several of those years were outfitted with AC, so if pre-'63 pulleys are the same you should be able to find a stock one..."
unfortunatly my stuff's on 2 shive (not a bad thing to have) & usually 250/4.1. However U will see some below - also w/a prt # which is pretty darn handy. May B just use the web site linked?
C9ZZ-8509-A .. Double Sheave Water Pump Pulley - 5 29/32" O.D. / Marked: C9ZE-A or B / Obsolete
2 groove H2 Pump pulleys (and more at)
http://www.mustangtek.com/pulley/Pulley.html
here's some numbers:
D1OE-8509-AA
D1OE-AA 71 250 Torino w/AC
71 250 Mustang w/AC
71-72 250 Maverick w/AC
72 250 Mustang w/AC 2 Grooves
6 7/16" dia
D1OZ-8509-B
D2OE-BA 72 250 Torino Integral/AC 2 Grooves
6 7/16" dia
D2OZ-8509-B
D0OE-8509-J Torino Water Pump pulley 2 Grooves
C9ZE-A
C9ZE-B 69 250 Fairlane/Torino w/AC
69 250 Mustang w/AC
70 250 Torino w/AC
70 250 Maverick w/AC 2 grooves
5 29/32" diameter
C9ZZ-8509-A
D1OE-8509-AA
71 250 Mustang w/AC
6 7/16" dia
D1OZ-8509-B
6 7/16" dia
D2OZ-8509-B
C9ZE-A
69 250 Mustang w/AC
70 250 Torino w/AC
5 29/32" diameter
C9ZZ-8509-A
C5DE-8509-A 65 200 Fairlane w/AC
65 200 Fairlane XC(w/PS & auto/trans)
65 200 Mustang AC (w_or-wo/PS)
65 170 200 Falcon AC (w_or-wo/PS)
66 200 Fairlane Integral/AC-w_or_wo/TE
66 200 Fairlane HangOn/AC-dir. wo/TE
66 200 Mustang HangOn/AC w_or-wo/TE
66 170 200 Falcon Integral/AC w_or_wo/TE w_or_wo/PS
66 170 200 Falcon HangOn/AC wo/TE
67 200 Fairlane AC w_or_wo/TE
67 200 Mustang AC w_or_wo/TE
67 170 200 Falcon AC w_or_wo/TE w_or_wo/PS
2 grooves
5.00" diameter
C5DZ-8509-A
C4ZE-8509-A 64 Mustang 170-200 6-cyl wo/AC w/PS
65 Mustang 170 w/PS(exc w/AC)
65 170 Falcon PS(exc/AC)
66 200 Fairlane (PS exc/AC-fact,dir.), 53·55amp wo/TE
66 200 Fairlane std.(PS exc/AC), 53·55amp, Power_fan, w/TE
66 Mustang 200 std.(exc w/AC), (PS-factory)-XC w/TE
66 Mustang 200 w/PS-factory, dir. wo/TE
66 170 200 Falcon PS-wo/AC wo/TE
66 170 200 Falcon std,(PS exc/AC), XC w/TE
67 200 Fairlane Std., PS, XC, Power_fan, 53amp, w/TE before_14-nov-66
67 200 Fairlane (exc/AT_w/Imco or AC)-w/TE from_14-nov-66
67 200 Fairlane PS, (53·55amp wo/PS)-wo/TE
67 200 Mustang PS wo/TE
67 200 Mustang Std.(exc/AC),PS, XC-w/TE before_14-nov-66
67 200 Mustang ST(exc/AC) w/TE from_14-nov-66
67 170 200 Falcon PS, (53·55amp wo/PS), wo/TE
67 170 200 Falcon Std, PS, XC, wo/TE before_14-nov-66
67 170 200 Falcon ST(exc/AC) w/TE from_14-nov-66
68 200 Fairlane w/55amp.w/Imco wo/AC, w/std&55amp.w/TE wo/AC
68 200 Mustang wo/AC, w/TE
68 200 Falcon wo/AC, w/TE 2 grooves
Diameter : 5.625"
Overall depth : 1.85"
3/8" belt groove
C4DZ-8509-A
C4GE-8509-K
or
C4GE-8509-A 65 200 Mustang PS (exc/AC)
65 200 Falcon PS (exc/AC)
68 200 Fairlane w/AC or PF, w/TE or Imco
68 200 Mustang w/AC
68 200 Falcon w/AC
69 200 Mustang w/AC
69 170 200 Falcon w/AC
70 200 Mustang w/AC
70 170 200 Maverick w/AC
70 200 Falcon w/AC
71-72 200 Maverick w/AC 2 grooves
4.98" diameter
C5AZ-8509-K
C0DE-8509-A 65 200 Fairlane HangOn/AC (XC-wo/PS)
65 170 Mustang (exc/AC or PS)
65 170 Falcon (exc/AC or PS)
66 200 Fairlane std.(exc/PS,AC,53·55amp)-wo/TE
66 200 Mustang std. (exc.PS, AC) wo/TE
66 170 200 Falcon std.(exc/PS, AC) wo/TE
67 200 Fairlane std.(exc/PS,AC,53·55amp)-wo/TE
67 200 Fairlane AT_w/Imco(exc/AC)-w/TE from_14-nov-66
67 200 Mustang std. (exc.PS, AC) wo/TE
67 200 Mustang AT_w/Imco(exc/AC) from_14-nov-66 w/TE
67 170 200 Falcon std., wo/TE
67 170 200 Falcon AT-w/Imco((exc/AC)- w/TE from14-nov-66
68 200 Fairlane w/std_alt.wo/AC
68 200 Mustang wo/AC w/Imco
68 200 Falcon w/Imco wo/AC, PF w/55anp
69 200 Mustang wo/AC
69 170 200 Falcon wo/AC
70 200 Mustang wo/AC
70 170 Maverick (AT)-wo/AC
70 200 Maverick wo/AC
70 200 Falcon wo/AC
71 200 Maverick wo/AC wo/PS
72 200 Maverick wo/AC 1 groove
5.60" diameter
1.88" overall depth
C0DE-8509-A
