This might not help. But this subject made me think of my old website. I found my html pages on an old hard drive. See Below:
Tips On The Autolite 1100 (The Misunderstood Carburetor)
CFM Rating = 185
Stamping Numbers = C5OF-E, C5OF-H, C5OF-R, C5OF-S, C5OF-N
Parts Nubmers = C5OZ-9510-B, C5OZ-9510-G, C5OZ-9510-C, C5OZ-9510-D, C5OZ-9510-E
The numbers listed above are for a 1965 200 CID Mustang. The Autolite 1100 was also used on the 144 and 170 engines. Plus on the Falcon, Failane, Ford Taxicabs and Police Specials.
For automatic choke carbs clean out the groove on the carb spacer/heater plate or the choke will not operate properly. (This is a vacuum passage)
groove
Use the proper gasket from the spacer to the carb. This is a 4-hole gasket. It lets the groove from the spacer plate line up with the hole on the bottom of your carb.
gasket
Always use a new fuel filter with the installation of your carb and use teflon tape on the threads of the filter. Two to three layers or wraps are fine, but Do Not put the tape over the opening of the filter. Pieces may shred off and get stuck in your carb. Instead, start the tape at least 1 to 2 threads back from the opening of the filter.
There are really only two on car adjustments that can be made to your carb.
1. Adjust the curb idle speed with a hot or warmed up engine, to 650-700 rpms in neutral or 550 rpms in drive with a automatic transmission. The screw is located on the rear of the carb, drivers side.
2. Adjust the idle mixture screw. Turning it in or clockwise, shuts down the fuel or leans it out. Backing it out, adds fuel or richens the mixture. To adjust, turn the screw in until the engine slows down. Then back it out until the engine slows down again. Finally, turn it back in once more until the engine runs the fastest. You are also looking for maximum vacuum at about 19 pounds. The screw is located on front passengers side of the carb.
Autolite 1100
Autolite 1100 Exploded View
© Copyright 2001. All rights reserved. Contact: 65coupei6 Powered by Inline Performance
