time to rebuild the 170..
falcondave63
Post #1 by falcondave63 » Wed Feb 11, 2009 5:56 am
before the end of car show season last year the falcon's 170 would hesitate under acceleration and the idle would hunt fomtime to time. i went through the bolts on first. the carb is new and adjusted properly. timing is adjusted properly..advanced as suggested. the air filter is new (k&n) plugs and wires are new as is the fuel filter. this led me to do a compression test. all were pretty low. #4 was the worst at around 90psi. the others around 110-120psi. adding oil to #4 only raised the compression a couple psi..valve problems i suspect. so with that in mind, my plan is a full rebuild. i cant see freshening up the top end without touching the bottom end. i plan on yanking the engine, ordering a new exhaust manifold (rear ear is broken off), having the completely head re-done with all new valves and seats, valve guide seals etc, i'm going to hot tank the block and paint it. i'll check the main and rod bearings, i'll replace all rings on each piston and supply the engine with a complete array of fresh gaskets. my dilemma is where to get all of the parts. i need to find a reputable supplier of quality parts. whats brands have you guys felt were top notch as far as engine rebuilding is concerned?
63 Falcon 170 3spd Wimbleton White 99K
05 RX-8 Sport 6spd brilliant black 37K
88 F-150 302 5spd 4wd 126K
80 RX-7 Leather Sport 61K solar gold. 5spd.
84 RX-7 GSL-SE 82K sunrise red 5spd
85 RX-7 GS 143K ocean blue 5spd
85 RX-7 GSL sparkling black 114K 5spd
88 RX-7 10th Anniversary 97K
92 Camry SE 130K 3VZ-FE 5spd
falcondave63
Post #2 by falcondave63 » Wed Feb 18, 2009 3:50 pm
any tips would be most appreciated
rbohm
Assistant Admin
Post #3 by rbohm » Wed Feb 18, 2009 5:19 pm
8) federal mogul, trw, speed pro, all are good parts to use for bearings and rings. as for pistons, speed pro and trw are the best imo for the street. that said however, most of the "white box" parts start with the name brand base stock. for example, badger and triplex pistons start with trw blanks and those companies do their own machine work. fel pro makes the best gaskets imo, and all these parts can be purchased at most any auto parts store, like checker. if you have problems getting parts from there, get PAW's catalog, check out this link;
http://www.pawengineparts.com/
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
falcondave63
Post #4 by falcondave63 » Thu Feb 19, 2009 5:21 pm
thank you for the heads up. i'm looking into sealed power rings and bearings. what do you guys think of those? i'll prob use all felpro gaskets to button the engine up.
rbohm
Assistant Admin
Post #5 by rbohm » Thu Feb 19, 2009 8:34 pm
8) sealed power is another company that makes very good parts.
64 falcon
66 mustang
05 grand marquis
of invention
champion2211
Engine Rebuild
Post #6 by champion2211 » Sat Mar 14, 2009 8:19 pm
The first thing is to tear it down and see what parts you need. Has the engine been bored? Has the rods and mains been resized? You need to look at all the parts first to determine what the sizes you need. A reputable machine shop that does the head will check it for cracks and the seats and valves. I have already gone through this before and it is important. Good luck.
falcondave63
Re: time to rebuild the 170..
Post #7 by falcondave63 » Mon Nov 08, 2010 10:08 pm
the engine has never been opened up. at this point in its life, i think it will need to be bored 10 over at maxiumum. i do need to replace the exhaust manifold as an ear has cracked off. i hope to get it out of storage and into my shop within the next couple of months. a friend of mine runs a very successful machine shop that specializes in sprint car engines. i have had nothing but excellent dealings with their staff and am confident that they can tell me what i will need. i'm considering installing a very mild cam just for a hair of extra low end grunt. this is however my baby and is 100% bone stock and i would like to retain that as much as possible.
