Speedometer Gears
David_Conwill
Speedometer Gears
Post #1 by David_Conwill » Fri May 15, 2009 10:09 am
This is a long shot, because I haven’t even had any luck with my extremely-common Camaro-and-Muncie combination, but is there a good source for speedometer gears that might match an S10 T5 or Toploader overdrive with the stock speedo in my Futura?
-Dave
1962 Falcon DeLuxe: 250/T5/8"/Scarebird discs.
David_Conwill
Re: Speedometer Gears
Post #2 by David_Conwill » Tue May 19, 2009 11:55 am
So everybody with a T5 is driving around with a disconnected speedometer?
-Dave
Inliner
Post #3 by Inliner » Sat May 23, 2009 1:13 am
Hi Dave,
Why can't you use the original gear again?
John
Eric Rose
Post #4 by Eric Rose » Sat May 23, 2009 11:16 pm
I'm sure Mustangs Unlimited, Summit, or any of the other big suppliers will have the right gear for you. The T-5 takes the same gear and cable as all other Ford manual transmissions. Really the only variables are what rear-end ratio you have and the height of your rear tires. There are plenty of "speedometer calibration" websites that will tell you how many gear teeth you need for your particular tire size and rear end ratio. :thumbup:
I got 350 heads on a 305 engine. I get 10 miles to the gallon, I ain't got no good intentions.
- Mike Cooley, aka the Stroker Ace.
SoCar72
Post #5 by SoCar72 » Mon Jun 01, 2009 6:58 pm
Modern Driveline carries a wide assortment of Speedo cables and conversions as well as Speedo gears for the T5's : V8, L4, and S10 tailhousings.
http://www.moderndriveline.com/
Just ordered a Cable and Gear for my upcoming conversion. Just tell 'em what trans, rear gear, and tire size you have...they'll set you up.
'63 Falcon 4dr, 170 stock, 3.20:1 7.25"
T5 ('85 Mustang 5.0) 3.35 1st - 0.68 5th, 25mpg city / 27mpg hwy
Pertronix Ignitor II & Coil, 16x7 Cragar 345's re-bored for 4-lug, 215/60 R16 BFG's
'69 Mach 1, 351w modified, 4sp Top Load, 3.00 9", Torq-Thrust II's 17x8f, 17x9.5r, 245/45f, 275/40r
'79 F-250 2wd, 300, Offy with 470 Holley T/A, Hedman Long Tubes, 4sp OD MT, 3.40 Dana 60
mustang6
Post #6 by mustang6 » Mon Jun 08, 2009 3:19 am
Actually Ford 4 speed manual transmissions use a driven gear that is opposite cut from Ford 3 speed manual transmissions. The T-5 uses the same cut gear as the 3 speed transmissions.
Scott
powerband
FSP Moderator
Post #7 by powerband » Mon Jun 08, 2009 8:40 am
Yeah , be careful out there. Speedo gears are Ford family specific. Plug the Speedo 2.77 gear in a Toploader and besides no speedo, the gear will be toast - but probably no real damage done .
Toploaders and T5's and from what I read - C4's, use same gear. I have a selection of the gears sold by multiple vendors. Depending on Tranny Speedo gear, OD ratio, Rear Axle ratio and tire size , several "Optimum" gears can be figured. T5's also used three different speedo drive gears which are ID'd by their Color.
I just put an '84 non-world class NWC T5 in place of a 90's Cobra/Z-T5 and needed to change the 23 to 19 tooth gear as Speedo read UNDER - closest available gear is 20 which is as close as speedo anyway..., here's why:
donated chart:
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Manual Transmissions with 8 Tooth Drive Gear 1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
Automatic Transmissions with 7 Tooth Drive Gear 1983-1989 Automatic Transmissions
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Here's a link for T5 speedo gears calculator:
http://www.hanlonmotorsports.com/t5speedo.asp
Have Fun...
" Everything in my garage has a story ..."
stu in wichita
Post #8 by stu in wichita » Thu Feb 03, 2011 2:03 pm
I'm confused. :? Which gear works with a T5?
I'm ready to hook up my '61 Ranchero, and the existing cable was on the original automatic. I assume it's the same gear as for a 2.77 3-speed, but maybe not. Does anyone know for sure?
Also, on all of these variations, is it just the gear that is different, or is there a difference in the cable end as well? The diameter seems to fit, but is there any difference in depth?
Thanks for any clarification.
-Stu
Users browsing this forum: No registered users and 22 guests
