Leaf Springs
FrankBoss
Leaf Springs
Post #1 by FrankBoss » Sat Dec 12, 2009 2:55 pm
I post this every once in a while ..Looking for options.. I need new Leafs for the back of my 60 wagon.
I want it up in the air a little.
Espo and Jc Whttney told me they are no longer available.
Frank
1960 Falcon 2 Door wagon *new 3.3L comp260 Cam* FrankBoss Carb adapter 5200 Holley. Duraspark 2 conversion MSD Blaster 3 coil,Altinator conversion, 8 inch rear end.5speed
Soon to have Oz 2V (found a Intake) now machining for over sized valves
1972 Pinto~ *289 Dual4's, 4 speed*
I'm always looking for Pintos or parts.
1984 Ranger *2.3L EFI IC Turbo & 5 Speed*
PintoWorks.com
rbohm
Assistant Admin
Re: Leaf Springs
Post #2 by rbohm » Sat Dec 12, 2009 6:29 pm
8) autokrafters can have new springs built for you for about $250.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
FalconSedanDelivery
Re: Leaf Springs
Post #3 by FalconSedanDelivery » Sat Dec 12, 2009 8:23 pm
Here is an E-bay Store Shipping is a bit much ( but hey they are heavy ) , but he has them http://stores.ebay.com/McVeighs-Truck-Springs?_rdc=1
Falcon 6's, FE's I Like them both , Sold all My 6 cyl stuff ( for now at least ) glad to pass along some tips though
FrankBoss
Re: Leaf Springs
Post #4 by FrankBoss » Mon Jan 04, 2010 1:32 pm
Thanks guys...
Frank
PintoWorks.com
Henning_1966
Re: Leaf Springs
Post #5 by Henning_1966 » Mon Jan 04, 2010 3:32 pm
Frank you might try this place it is in wichita ks and shipping with beaver express should be reasonable. I got the springs for my mustang from them great springs if they don't have it they can build it for you.
Atlas Spring & Axle Co Inc
(316) 943-2386
joedaubach
Re: Leaf Springs
Post #6 by joedaubach » Thu Jan 07, 2010 10:47 am
I purchased some 63 comet convert leafs from www.mcveighstrucksprings.com and they were cheaper than a lot of other places and they fit great.
Joe
JOE
63 Comet S-22 Conv.
papawfalcon
Re: Leaf Springs
Post #7 by papawfalcon » Fri Jan 08, 2010 9:15 pm
I bought mine from Jc whitney .Years ago.For my RANCHERO,I recomend to check the spring rate. Mine is not strong enough. I have heard that McVeigh's is better than good.
FALCONS AND RANCHERO'S FOREVER
FrankBoss
Re: Leaf Springs
Post #8 by FrankBoss » Mon Jan 11, 2010 3:32 pm
yah I was going with Mc viehs... I'm needing the rear up and not saggin while pulling my little trailer.
Good call
Frank
PintoWorks.com
Re: Leaf Springs
Post #9 by bubba22349 » Tue May 25, 2010 6:03 pm
If you can find another set of spring you can take apart the spring pack and add a few leaves to yours all you need are some clamps or pipe clamps and a new center bolt. Will add some stiffness but if you got creative you could do like on a 3/4-ton pick were it would be progressive as you added weight.
