shaved column
kevinl1058
shaved column
Post #1 by kevinl1058 » Thu Jan 21, 2010 9:16 pm
Edit postReport this postReply with quote3 speed column shift removal
by kevinl1058 » Mon Jan 18, 2010 10:50 am
Now that I have the 5 speed in I removed the shifter stub off the column. Came out real nice. I cut off the stub, plugged it with 1/2" dowell plug, then used some JB weld to smooth it all out. Little spot putty and done. Duplicor had the perfect match and done.
David_Conwill
Re: shaved column
Post #2 by David_Conwill » Thu Jan 28, 2010 10:48 pm
Looks great. Where did you get the 1/2-inch dowel?
-Dave
1962 Falcon DeLuxe: 250/T5/8"/Scarebird discs.
LaGrasta
Re: shaved column
Post #3 by LaGrasta » Fri Jan 29, 2010 1:30 pm
Wow, that came out really smooth! :)
Nice job. :beer:
1963 1/2 Falcon 170/C4/8" (alt, a/c, Petronix/42v coil/8mm wires, 16" electric fan, electric fuel pump, Holley 1940, K&N Harley air filter, power dual m/c, 11" disc, 3" drop, Shelby drop, white tuck/roll, Moon steering wheel, '59 Caddy tail lights, fishtail exhaust tip, shaved trim, handles, cowl, fuel, dash, 4" radius trunk/door corners, power windows, 600w iPod system)
kevinl1058
Re: shaved column
Post #4 by kevinl1058 » Tue Feb 02, 2010 2:28 pm
Just picked up a dowell rod at a home depot. Only needed an inch of so now its a play stick for my son. kids can be very creative... Plugged the hole used some gorilla glue to seal it . JB weld to seal the side, then a little spot putty to clean it up. Duplicolr to match and done.
michael_cini
Re: shaved column
Post #5 by michael_cini » Tue Feb 02, 2010 4:12 pm
smart! looks good too.
63 futura convertible sport coupe,
250 I6/C4, OZ head (milled, oversized valves), Holley 350cfm carb, 264/274-110 cam, 6 into 1 header, 2.5 exhaust with dynomax super turbo muffler, granada disc brakes, 5 bolt 8" rear.
BTW, it's pronounced Chee-knee.
