rear seat removal in a 61 2 door
DOMER94
Post #1 by DOMER94 » Fri Feb 26, 2010 11:10 pm
couldnt find anything on this in the shop manual. any advise would be welcome
thanks
kevinl1058
Re: rear seat removal in a 61 2 door
Post #2 by kevinl1058 » Sat Feb 27, 2010 12:16 am
I have a 61 and it should just slide out?
Falconman62
Post #3 by Falconman62 » Sat Feb 27, 2010 5:47 am
I am pretty sure there are two tabs that hold the seat part down in the front. You need to carfully place something under the front of the seat to pry it up and it should release. When the seat is loose it should slide forward (twards the front of the car) leaving just the seat back. The seat back has a couple of screws through the trunk side that need to be pulled, then it slides up and out. Well Best of luck
:beer:
DOMER94
Post #4 by DOMER94 » Sat Feb 27, 2010 11:19 am
thanks very much. sounds like that makes sense. wanted to make sure before pulling and prodding !!
aribert
Post #5 by aribert » Mon Mar 01, 2010 10:04 am
I strongly suspect that the retention brkt in a 2 door is in the same place (cross car) as the 4 door. Pry on the front lower edge of the seat cushion frame about 9 inches inboard from the rocker inner. Should pop right up and then slide forward as others have mentioned. I can pop my rear seat out with just using my fingers (no tools). Reinstall is the reverse - seat cushion frame in place and press down until the frame snaps over the retention brkt.
61 , Deluxe trim & original 54 yr old factory padded dash. Custom interior, stock color base/clear, 275K mi, My car for the last 47 years (OK, first decade "ownership" from the left rear seat). '78 200, 3.03 manual trans, '73 dist w/ points & TFI ign, Weber32/36, 15 wheels Image
91 F150 4.9 almost stock
Users browsing this forum: Majestic-12 [Bot] and 2 guests
