fluid for fordomatic 2 spd and rear end
DOMER94
Post #1 by DOMER94 » Wed May 05, 2010 8:07 pm
does anybody have a good suggestion as to what best to use in the trans and rear?
Crosley
Re: fluid for fordomatic 2 spd and rear end
Post #2 by Crosley » Thu May 06, 2010 12:08 am
Is the automatic trans fresh rebuild or old? Either Dexron or Ford F fluid will work fine
Use gear oil in the differential. 80-90 weight is fine
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
DOMER94
Post #3 by DOMER94 » Thu May 06, 2010 9:46 am
thanks crosley... i believe was a rebuild within 5 years or so. i was looking in the original manual for recommended fluids , but wasnt sure if there was something better and more modern now that guys are using.
DOMER94
Post #4 by DOMER94 » Tue May 11, 2010 4:59 pm
i ended up picking up 85w-140 gear oil. i couldnt find straight 80 - 90. will this be ok in the rear end?
Post #5 by bubba22349 » Mon May 17, 2010 7:30 pm
The the 85 - 140 is good will work fine. Ford specs recommended type F gives firmer shifts that trans was designed for slippage equals more heat. Dextron has more slip built into it even the gm racers use to use the type F to get firmer shift. Your choice but I would only use the F in the old Fords into 1970's.
