ford-o-matic filter, seals and gasket
smalltown62wagon
Post #1 by smalltown62wagon » Sun May 09, 2010 4:15 pm
where can i find the right gasket, seals and filter for my 2 speed ford o matic that is in my 62 wagon? i am in nor-cal but would prefer to buy online.
i bleed 30w
Crosley
Re: ford-o-matic filter, seals and gasket
Post #2 by Crosley » Sun May 09, 2010 10:55 pm
EDIT:
I did some research in my parts books since it has ben a while since I worked on a 2 speed Ford.
Pump - converter hub seal is common, easy to get.
tail housing seal is common , possible it is 2 sizes. Both are common use , easy to buy.
I have not checked on pan gasket , the parts house was closed
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
cruzingratiot
Post #3 by cruzingratiot » Tue May 11, 2010 10:30 pm
Donate Life
6-7-04 Liver Transplant Recipitant
http://www.iaod.org/ International Association for Organ Donation
http://www.donatelife.net/ U S A for Organ Donation
Thank You
My Ranchero Album click here
Crosley
Post #4 by Crosley » Thu May 13, 2010 8:18 pm
I edited my first post... the front & rear seals are easy to get, very common.
Pan gasket and filter , I have not checked on at the parts house
Tony in AZ...
smalltown62wagon
Post #5 by smalltown62wagon » Thu May 13, 2010 11:26 pm
thank you so much will check it out
i bleed 30w
