69 falcon in junk yard flawless body
64 200 ranchero
Post #1 by 64 200 ranchero » Thu Jun 10, 2010 8:23 pm
at ecology in santa fe springs, it came with a 250, all driveline is there block looks good
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
sp_alloy_head
Re: 69 falcon in junk yard flawless body
Post #2 by sp_alloy_head » Fri Jun 11, 2010 7:32 pm
Are the motor mounts and frame mounts still there?
64 200 ranchero
Post #3 by 64 200 ranchero » Sat Jun 12, 2010 2:32 pm
yes
64 200 ranchero
Post #4 by 64 200 ranchero » Sat Jun 12, 2010 4:43 pm
it also has rack and pinion steering
jahearne
Post #5 by jahearne » Sat Jul 24, 2010 11:20 pm
Those motor mounts are hard to come by. It's what you need to install a 250 into a Falcon, Fairlane, Comet or Ranchero 66 on up.
John
'67 Ranchero 250 AOD
'66 Mustang Fastback
'65 Chris Craft Super Sport
'60 Chris Craft Constellation
