Tranny swap?
papawfalcon
Tranny swap?
Post #1 by papawfalcon » Sat Jun 12, 2010 2:36 pm
My son wants to put a C-4 in his '63.The tranny works fine was told it was rebuilt? The problem is he wants a daily driver that can go 65-70 mph on the interstate we live on the interstate.What is the 2-sp worth and do we need to change the rearend if so what gears. I know that if the rearend was changed that it would need a maverick. Thanks Ken N.
FALCONS AND RANCHERO'S FOREVER
rbohm
Assistant Admin
Re: Tranny swap?
Post #2 by rbohm » Sat Jun 12, 2010 8:19 pm
8) the two speed ford o matic and the three speed C4 have the same top gear ratio of 1:1, thus top speed wont be changed. now depending on what rear end ratio he has, 65-70 should be an easy thing to do. my 64 falcon goes that fast with a motor that is losing compression while pulling a 600lb trailer, and a trans missing second gear. i have the 3.20 rear end gear.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
papawfalcon
Re: Tranny swap?
Post #3 by papawfalcon » Sun Jun 13, 2010 2:59 pm
pulled the rear-end tag off eairler and cleaned it up. Tag read 3.10 will that gear work for me if im running 65-70 mph
thanks nick
rbohm
Assistant Admin
Re: Tranny swap?
Post #4 by rbohm » Sun Jun 13, 2010 9:39 pm
8) yep that will do fine. my falcon has the 3.20 gear and it can run 75-80 with no issues.
64 falcon
66 mustang
05 grand marquis
of invention
