new shackle bushings, new vibrations grrrr!
64 200 ranchero
Post #1 by 64 200 ranchero » Fri Sep 17, 2010 3:28 am
i just installed new shackle bushings on my ranchero, now when i go over 60mph my car vibrates like its going to fall apart, did i over tighten them?, i also found that my new rear end seal blew out, i just rebuilt the whole rear end like a month ago :evil:
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
1bad6t
Re: new shackle bushings, new vibrations grrrr!
Post #2 by 1bad6t » Fri Sep 17, 2010 8:30 am
Vibration could be from the rear end and this caused the seal to blow
Jeff in Georgia
'74 Maverick 250/C4
Frankenstang
Post #3 by Frankenstang » Fri Sep 17, 2010 8:22 pm
Assuming the shackles are a matched set...IIRC shackle bushings should be final torqued with the axle/wheels on the ground...don't know if this is your situation...but I would assume it might be possible if you torque them with the axle off the ground (and maybe the shackles at slightly different angles...which might result in the axle out of allignment with the frame) to induce vibration :hmmm: :?:
If this only occurred since changing the shackles then I would manuallly check alligment from fixed points (as best you can) with a tape measure. Then inspect the usual suspects, u-joints, loose mounts, loose axle u-bolts, pinion angle, etc.
Good luck!
PS also recall reading earlier falcons having narrower springs...might make sure the shackles you've got are not too wide...too much play
-Robert
66 Mustang 200+30, 67 BH, 89 4cyl T-5, 71 Comet 4 lug 8" 3:1rear, 85 T-Bird v6 DS, 10 Mallory Unilite Hyfire VI-A, 08 Vaporizer 1bbl, 68 Cougar 2" exhuast,65 pipe, 74 Mav man disc m/c & Scarebird(87 Stanza rotors 89 Cavalier calipers), 73 Datsun 240z Appliance Wire Mags, 03 Mustang Leather seats
All in one car! Johnny Cash would be proud...I got it One Piece at a Time
64 200 ranchero
Post #4 by 64 200 ranchero » Sat Sep 18, 2010 5:24 am
thanks ill check that out
1bad6t
Post #5 by 1bad6t » Sat Sep 18, 2010 9:44 am
'60-'63 Falcons have a 2" leaf spring...'64-up have 2.5" spring. You are correct about tightening things up at ride height. Same goes when replacing front suspension parts.
Jeff in Georgia
'74 Maverick 250/C4
64 200 ranchero
Post #6 by 64 200 ranchero » Tue Sep 21, 2010 3:26 am
i just found a big bubble on my front pass tire, thats prob it :?
