Better steering question
papawfalcon
Post #1 by papawfalcon » Mon May 09, 2011 12:27 pm
In the search for better steering on my '62 Ranchero. I know that the '65 Falcon steering is deamed 2nd after rack and pinion. But when tring to buy a center link for a '65 starts at $150. On another fourm a man used granada steering with different outer tie rods.Now the question is what is the fram width of a Maverick compared to Falcon. Wondering if the Maverick steering can be used on a Falcon. The Maverick center link is about $55.Thanks for thoughts. Ken N.
FALCONS AND RANCHERO'S FOREVER
cruzingratiot
Re: Better steering question
Post #2 by cruzingratiot » Mon May 09, 2011 8:31 pm
i dont think this will help
but they are about upgrading and part numbers
http://www.cometeastcarclub.org/PDFs/St ... pgrade.pdf
http://www.falconparts.com/ford-falcon- ... on-d19.htm
Donate Life
6-7-04 Liver Transplant Recipitant
http://www.iaod.org/ International Association for Organ Donation
http://www.donatelife.net/ U S A for Organ Donation
Thank You
My Ranchero Album click here
Post #3 by bubba22349 » Tue May 10, 2011 2:08 am
It’s not likely to fit, as the center link width is set by the chassis width the Mavericks and the other Fords ie Falcons Mustangs are wider 1967 up. So only possible parts will be those that measure the same as the 62 at pitman arm center to center and at the idler arm mounting points no matter what steering box you use.
