Rubbing sound coming from 63 futura
stock63futura
Post #1 by stock63futura » Thu Feb 09, 2012 11:22 am
Hello,
I recently bought a 63 futura. There is a rubbing sound come from the drivetrain and/or transmission. It only make the sound is 1st and 2nd gear, not so much in 3rd. At first I though it was the passenger side front brakes dragging, or even the bearing, but I repacked the bearings and got a brake job. So, Im at a loss, I would really appreciate any suggestions/advice.
Thanks!
-Brian
-Brian
MPGmustang
FSP Moderator
Re: Rubbing sound coming from 63 futura
Post #2 by MPGmustang » Thu Feb 09, 2012 12:24 pm
check to see if the started is tight, had that happen to me once for 3 months untill the starter went. lol :bang:
check to see if the trans has enough fluid
the alt bearings do go out, I had one recently die and the 'dummy' alt light never came on. it seemed find in higher rev but lower rev it would just moan and groan.
could be the water pump bearings
could be your belts are too tight??? IDK just throw'n it out there.
As you have a heat issue, the alt and the water pump both would be the first things I check.
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
stock63futura
Post #3 by stock63futura » Thu Feb 09, 2012 3:59 pm
Right on, thanks. I will check that stuff.
I appreciate your help.
-Brian
stock63futura
Post #4 by stock63futura » Thu Feb 09, 2012 4:30 pm
How do I get to the tranny fuild, there is no dipstick. Someone said I have to pump it in from the side of the tranny, through an access hole?
-Brian
Post #5 by bubba22349 » Thu Feb 09, 2012 5:06 pm
Right! :nod: Just pull the plug oil level should be right near the hole opening :thumbup:
Users browsing this forum: No registered users and 21 guests
