Fix it or Fling it ?
oldgrezmonke
Post #1 by oldgrezmonke » Thu Mar 22, 2012 7:47 pm
I have been trying to find a '60-61 air cleaner assembly or even just the base . i thought I had found one but when I cleaned it up I found damage to the base . I worked out a refund with the seller and kept the parts . I have an idea how to repair it but let's see what the consensus is here . Maybe someone will have a better idea . In the first 4 pictures the tube that attaches to the carb airhorn is already apart from the base [Yeah , that damaged] . That part is in good shape . The last picture is how it should look .
http://img821.imageshack.us/img821/4228 ... lingit.jpg
http://img252.imageshack.us/img252/1728 ... ingit2.jpg
http://img801.imageshack.us/img801/7393 ... ingit3.jpg
http://img171.imageshack.us/img171/3430 ... ingit4.jpg
http://img62.imageshack.us/img62/2725/baseinside.jpg
First car - 1961 Falcon Deluxe 4door , had 1968-73
Present - 1963 1/2 Falcon 4door base model , since 2009 ,
frequent driver , work in progress
Yes I like 4doors
Lifetime member # 117 NSRA
Former A.S.E. certified mechanic
FCA member # 13677
Admin FFOG
Re: Fix it or Fling it ?
Post #2 by bubba22349 » Thu Mar 22, 2012 9:38 pm
If you have a way to weld it then I would fix it should not take very long to hammer it straight and weld.
