Rebuild, salvaage, or ??? 64 Falcon steering box
Falconman62
Post #1 by Falconman62 » Tue May 22, 2012 4:37 am
Hey guys have a 1964 Falcon Futura the needs the steering box (non-power if it matters) either rebuilt or replaced. Have heard that I should got to a '65 steering box for parts are easier to find; is this true? Any other suggestions? Thx
Re: Rebuild, salvaage, or ??? 64 Falcon steering box
Post #2 by bubba22349 » Fri May 25, 2012 3:16 pm
I have a used 64 Sprint (V8) box complete with steering arm and column but than you need to use the V8 tie rods too. Your box can be rebuilt too. You might make sure your tie rod ends and idler arm are in good condition sometimes it's thought the steering box is bad when it's really the idler arm and or tie rods that are worn out. The 65 Falcon steering geometry was improved this is in the center link and the tie rod lengths, Not sure there was much of a difference in the steering box but the safest way to do swaps and be sure everything is compatible is of course is to swap everything together, IE the box, steering arm, idler arm, center link, and all the tie rods. Good luck
Thad
FSP Moderator
Post #3 by Thad » Sat May 26, 2012 10:41 am
Have new unused '65 box, pitman arm, cross link, Idler arm, steering shaft and rag joint -- all V-8 Ford Argentina. They made Falcon into the '90s
Anyone interested? make offer - start a bidding war ----
There are those who just dream,
and there are those who do more than dream. ><> = +
kukm66
Post #4 by kukm66 » Mon Jun 18, 2012 4:30 pm
I had mine rebuilt by CJ Automotive in South Gate, Ca.
They only charged $125 at the time, about 3-4 years ago.
They do a lot of rebuilds and have massive stock in the back room
Turn around time was only a couple of days. Ask them to rush.
5909 Firestone Blvd.
South Gate, Ca 90280
powersupply5909@aol.com
1964 Falcon Futura Convertible
1964 Ranchero
