Parts motor numbers
FrankBoss
Parts motor numbers
Post #1 by FrankBoss » Sun Dec 08, 2002 10:48 pm
I have a Issue with my parts stores telling me to pull a part off my car and they will match it up to something......Grrrr
I havent found a 2 speed electric wiper motor yet.
Can anyone send me a part # for this critter?
also they couldnt get me a 2 speed blower motor for my heater either.
its hard to drive my 60 if it has no heat or wipers in the winter,
Frank
PS : Phil as you can see I havent put the electric wiper mount in yet..but Thanks for the templet...
1960 Falcon 2 Door wagon *new 3.3L comp260 Cam* FrankBoss Carb adapter 5200 Holley. Duraspark 2 conversion MSD Blaster 3 coil,Altinator conversion, 8 inch rear end.5speed
Soon to have Oz 2V (found a Intake) now machining for over sized valves
1972 Pinto~ *289 Dual4's, 4 speed*
I'm always looking for Pintos or parts.
1984 Ranger *2.3L EFI IC Turbo & 5 Speed*
PintoWorks.com
Falcon62
Post #2 by Falcon62 » Mon Dec 09, 2002 10:23 am
No problem Frank. I'll see if I can get you a part number off of one of my wiper motors. If there's a number it will probably be a Ford #, but that may help. Who knows? Check the forum later today, around 6:00pm Pacific.
Phil, USAF Retired
Retired, ASE Master Re-Certified Collision & Refinishing Technician
'61 Futura 2dr
'62 Sports Futura, 200/C4
Falcon62
Post #3 by Falcon62 » Thu Dec 12, 2002 6:41 pm
Frank - I checked both motors and neither of them yielded anything more than "C0DB" and I'm afraid that won't help much. :(
Phil, USAF Retired
'61 Futura 2dr
Williboy
Post #4 by Williboy » Thu Dec 12, 2002 9:31 pm
According to my Hollander book; # C3DZ17508A 2spd. Comet 63-65, Falcon 63-65, Mustang 65,
The '66 and later use 2spd # C60Z17508D which fit alot of Fords
'61 Ranchero: '68 200, H/W 5200, DSII, 10SI Alt., C4, '65 Mustang floor shifter, Mav 3.00 8", Scarebird disc,
FrankBoss
Post #5 by FrankBoss » Thu Dec 12, 2002 10:07 pm
is that the wipers or the heter motor?
Wonder if NAPA can cros ref the numbers....humm.
Frank
PintoWorks.com
Williboy
Post #6 by Williboy » Thu Dec 12, 2002 10:12 pm
That's the wiper motor info; I got the heater info if needed
FrankBoss
Post #7 by FrankBoss » Thu Dec 12, 2002 10:32 pm
yes that would help..its like winter, Raining and snowing ...I need heat and wipers..:)
Frank
PintoWorks.com
Williboy
Post #8 by Williboy » Thu Dec 12, 2002 10:44 pm
The heater motor; #C0DZ18527A Comet'60-65, Falcon 60-65, Mecury 59-60 w/o fact. inst. A/C, Mustang early 65 to 4-1-65
Hope this helps,
It's going to get cold here in L.A. too!! Below 65 with rain!!! :wink:
FrankBoss
Post #9 by FrankBoss » Thu Dec 12, 2002 11:04 pm
yes that help greatly...I been looking at the Old Ford Place for parts But I know for fact the Classic Mustang which is next door is cheaper...and they have the parts.
Frank
PintoWorks.com
Hot 6t Falcon
One More thing
Post #10 by Hot 6t Falcon » Sat Dec 14, 2002 10:26 am
Frank,
One more thing for you to check as you're working on your heater. If you are haveing the inside of your windshield fog up on you when you run the defroster, you probably have a hole in the heater core that's leaking antifreeze. It fogs the windows something awful.
Good Luck
Dennis Schjeldahl, (say Shell-doll)
Co-Author of The Ford Falcon Performance Handbook
http://www.falcon6handbook.com
FrankBoss
Post #11 by FrankBoss » Sat Dec 14, 2002 1:15 pm
Deniss thanks
When i was told to pull the motor out so they can match it to a one speed they have in stock... I went out and bout a new heater core and heater box gasket kit.... I have had them for a few years, while trying to get the wipers and blower motor found localy...
But I'm making headway on these parts...better than my work on my 2.77..:(
PintoWorks.com
